Old 12-09-2017, 12:14 PM   #1
ZEKE68
ZEKE68's Avatar
What size cooler lines for 4L80E
Have found that GM used 5/16" cooler lines on the 4L80E until 1998. They must have gone to 3/8" when they moved the return line to the middle of the transmission case. All the radiators I have found for my 67 to 72 truck have 1.2" - 20 threads for 5/16" cooler lines so there will be some restriction at the radiator even if I run 3/8" lines to it. Thinking about splitting at the radiator and adding an aftermarket cooler in parallel to keep the flow up. Since GM ran 5/16" lines on the 4L80E in the early years I assume that unless I work the transmission hard I would be ok even if I stayed with the 5/16" lines.
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
Old 12-09-2017, 02:13 PM   #2
FL71C10
Re: What size cooler lines for 4L80E
The Roadmaster I took my 4L60E out of had a separate external cooler. I can look at the size of the lines on that.
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 12-10-2017, 02:26 AM   #3
Robznob11
Robznob11's Avatar
Wink Re: What size cooler lines for 4L80E
Run an aftermarket with 1/2 lines....Its cheap insurance. I run a derale with fan more than acquit bout 250 bucks for the whole kit. But they offer smaller ones a little cheaper. I went big for the 3800 stall 😜
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
