12-10-2017, 12:23 AM | #1 |
A/C lines
I'm getting closer to getting my a/c in my 71. I'm in need of getting custom lines. I'm running a serpentine drive from a 95 silverado, and so I'm trying to get lines that connect from it to the original a/c components from 71. thanks
12-10-2017, 09:38 AM | #2 |
Re: A/C lines
You can buy your own A/C fitting crimper from Amazon and make them yourself.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
12-10-2017, 10:32 AM | #3 |
laying low
Re: A/C lines
Or go to any auto parts store that makes hoses and have a set made.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
12-10-2017, 12:09 PM | #4 |
Re: A/C lines
Will they have the connector to fit the back of that compressor both lines are connected by an aluminum block if I order the lines from a 95 Silverado it comes both on that block can I cut the block off and have it custom from there?
12-10-2017, 12:31 PM | #5 |
Re: A/C lines
The original hose set will bolt to the '95 compressor - no problem. IIRC the issue is with the compressor being moved forward a few inches; the vapor hose is a little short.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
