Old 12-27-2017, 05:59 PM   #1
68chevystepside
68chevystepside's Avatar
Exclamation 04 tahoe swap....manifold question
I have an engine out of a 04 Chevy Tahoe i will be installing in my 68 stepside. I noticed the manifold that came with the engine has two holes for sensors? one towards the front and one towards the back. the back hole is for the sensor pressure but i have no idea what the hole on the front top of the manifold is for. I tried looking up the new dorman manifold for the vehicle and it doesn't have any sensor holes on top. can someone explain this. thank you
https://www.oreillyauto.com/detail/d...oe?q=intake+ma
https://imgur.com/qMKRZgj
https://imgur.com/gZklXON
https://imgur.com/L7Z2yNY
68chevystepside is offline   Reply With Quote
Old 12-27-2017, 06:42 PM   #2
GMC-YA68
GMC-YA68's Avatar
Re: 04 tahoe swap....manifold question
If you look at the mount where your sensor is on the rear....you should have the same thing in that empty hole up front. Looks like someone needed one.
you can sort of see what I'm talking about in this picture.
https://goo.gl/images/J4qCSQ
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 12-27-2017, 06:47 PM   #3
68chevystepside
so best to buy a new manifold. but the new one doesnt have the rear sensor hole. so what happens to that sensor??
Old 12-27-2017, 09:27 PM   #4
ls1nova71
ls1nova71's Avatar
Your intake is broken. I have seen that mount break off before. Another truck intake shouldn't be hard to find and are pretty cheap.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-28-2017, 01:58 AM   #5
dayj1
The MAP sensor is located on the back of the Dorman replacement intake.
^^This^^. I think Amazon has the Dorman intake for less than $300, but a used truck intake can be had for next to nothing.
dayj1 is offline   Reply With Quote
Old 12-28-2017, 09:38 AM   #6
ls1nova71
ls1nova71's Avatar
Just saw this, not mine, but may help you out. http://67-72chevytrucks.com/vboard/s...d.php?t=749092
