2005 GMC will crank but not start any ideas
I have a 2005 GMC 1500hd will crank over but will not run.Any idea where or what I should check.Thanks
![]() Join Date: Dec 2001
Re: 2005 GMC will crank but not start any ideas
Air, fuel, spark...any details on the truck like miles, maintenance, engine codes, etc would help. If it was running fine one day and not the next, I'd check the fuel pump. Usually you can hear them running to prime the system for a few seconds when you first turn the key on.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
Thanks I live in Nova Scotia Canada I got water in my gas and it we had some really cold nites working good now .thanks for the reply
I had a similar issue with my 03 2500 HD a few years back. I started it and back out of the garage to load some stuff in the bed and shut it off. Went to restart and it did nothing, no cranking or anything. My buddy who is a GM tech came over and did some testing. Turned out my ECM went bad and I had to have it towed to a GM dealer for replacement and reprogramming. Hopefully this is not your problem.
I found out what was wrong I put plugs and wires in it now it runs fine again. Should have did that first before checking everything else. thanks for your help
#6 | |
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg Last edited by RUN GMC; 05-20-2018 at 09:38 PM. |
