Old 01-02-2018, 04:12 PM   #1
paul mora
Exhaust Design LS conversion
I have 2006 6.0 I am installing in a suburban and a Blazer build I have not started. I have one set of stock exhaust that was on the 6.0 and a set so Sanderson headers that I have mocked up on the Suburban. I want to save the headers for the Blazer and use the stock exhaust on the Suburban.
I would like to coat the stock exhaust with a high temp coating and run them without the heat shields .
Does anyone see anything wrong with the exhaust plan, with the fit or no heat shields.
Pulatoy
paul mora is offline   Reply With Quote
Old 01-02-2018, 04:19 PM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Exhaust Design LS conversion
Stock truck manifolds usually do not fit without cutting the framerails. F-body, trailblazer SS, or Camaro LS3 are known to fit. Hooker or CPP exhaust manifolds also fit well, but are slightly more expensive
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-02-2018, 10:43 PM   #3
paul mora
I have two set one might be Camaro. Does any know the difference based on the part number stramped on the side
Pulatoy
Old 01-02-2018, 11:32 PM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Top is a truck manifold, bottom is Camaro LS3
-Chris
Old 01-03-2018, 01:13 PM   #5
paul mora
Will the Camaro work without cutting the frame and leaving the heat shields off
Pulatoy
Old 01-03-2018, 01:43 PM   #6
gringoloco
A guy with a truck
gringoloco's Avatar
Yes, they are a known good fit
-Chris
Old 01-04-2018, 02:23 PM   #7
Hart_Rod
Hart_Rod's Avatar
They work great!
+1
Hart_Rod is offline   Reply With Quote
