Old 01-03-2018, 06:45 PM   #1
robertsjm711
robertsjm711's Avatar
LS Flywheel Torque
I am installing a 5.3 with a Muncie M20 four speed and received my ARP bolts for my flywheel to crank today. In the ARP instructions it wants 85 ft lbs of torque, and all other GM info I am reading wants 74 ft lbs - Which one should I go with, ARP or GM?
It was said that if you cut off one hydra head, two more grow back.
-Lernaean Hydra
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=743246
robertsjm711 is offline   Reply With Quote
Old 01-03-2018, 09:34 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: LS Flywheel Torque
using arp bolts. ..arp bolts are in a class by theirself....I'd go with their recommendations....
.my advance adapters spec sheet called for 1st pass@15...2nd pass@ 37 ..and final pass@74
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-04-2018, 11:46 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
When using ARP Bolts, always use their torque specs, and always use the lubricant they include. As an example, torquing ARP head bolts to GM spec will not properly put stretch on the bolts, and change their strenght/yield points.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-04-2018, 12:00 PM   #4
robertsjm711
That is what I was thinking. I will use ARP specs, thanks for the input.
-Lernaean Hydra
Build Thread:
