01-04-2018, 03:46 PM | #1 |
Anyone see this NEW LS front accessory drive kit?
Desert |
01-04-2018, 03:51 PM | #2 |
Re: Anyone see this NEW LS front accessory drive kit?
Forgot the pic
Desert |
01-04-2018, 04:02 PM | #3 |
so much room for activities!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
01-04-2018, 05:46 PM | #4 |
I like how clean it looks. The price looks to be around $2,500. I think my friend gets a discount on Holley stuff. I might need to look into this more.
Thanks for the info. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
01-04-2018, 06:30 PM | #5 |
6>8 Plugless........
That looks nice, but man...... $2500? Have any of you checked out Murphy's stuff? I'm going to use his brackets on my 5.3 in my 71 Camaro.
http://www.lssimple.net/
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 01-04-2018 at 06:36 PM. |
01-04-2018, 10:38 PM | #6 |
The system looks really good...and compact. Priced at $1,800 from Holley and in December was on sale for around $1,600 as I recall.
https://www.holley.com/products/acce...s/parts/20-185 |
01-05-2018, 04:16 PM | #7 | |
Marc
01-05-2018, 08:56 PM | #8 | |
Probably price dropped due to competition. Which is great....anyone notice the Holley fuel injection priced to compete with FiTech? |
01-05-2018, 10:12 PM | #9 |
A320 Pilot/USAF Retired
That's a very nice set up!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
01-06-2018, 03:14 AM | #10 |
my only concern would be the custom waterpump
01-06-2018, 03:35 PM | #11 |
Great point, Might be good idea to by an extra water pump for down the road. Just in case availability is an issue down the road.
Desert |
01-06-2018, 03:56 PM | #12 |
doesnt the article say it uses an C7 vette pump?
01-07-2018, 05:59 PM | #13 |
Yes, that's how I understood it as well. I figured it was an off the shelf item if you needed to replace it.
Marc
01-07-2018, 06:06 PM | #14 |
It uses design elements of the C7 water pump. So, if a water pump goes bad, you will need one from Holley is how I interpret the information they provided.
Home / Accessories / Drive Brackets / Complete Kits / Holley Mid-Mount Complete Accessory System 20-185 - Holley Mid-Mount Complete Accessory System Image Larger Image HOLLEY MID-MOUNT COMPLETE ACCESSORY SYSTEM LS Engine Drive includes SD7 A/C Compressor, Alternator, P/S Pump, Tensioner, Belt, & Pulleys PART# 20-185 $1,999.95 Suggested Retail $1,799.95 Your Price Estimated shipping date: 01/22/2018 Free Shipping Qty: Add To Cart Starting at $159 a month with Learn More Fits ALL LS engines except with dry sump and/or supercharger. Original belt alignment is not a variable as the water pump and crank pulley are included. OVERVIEWSPECSTECH RESOURCES Holley’s Mid-Mount complete accessory system has all accessories pulled in tighter than other accessory drives. At the heart of the system is a “bracketless” design (Patent Pending), where the accessories bolt directly to the water pump for a clean, integrated form. The design offers superb engine visibility to show off your horsepower, not your accessories. Among the many swap friendly features are bottom heater outlets for clearance in tight applications. The Holley designed alternator is just as innovative. This premium alternator utilizes hairpin/square wire, 6-phase technology as found on the C7 Corvette. The water pump also shares its design efficiencies with that of the C7 Corvette. The compact and reliable SD7 A/C compressor and Type II P/S pump with baffled reservoir are also integrated. The Mid-Mount drive completes Holley’s trilogy of accessory solutions giving a third option compared to the High and Low-Mount previously released. All three accessory solutions are for LS engines. When we say “complete”, we mean complete. The Mid-Mount system comes with everything you need. All accessories are included; the water pump, A/C compressor, Alternator, P/S pump with reservoir, and the crank damper. All pulleys and the belt are supplied. Even heater hose adapters, power steering to -6 AN hardline, and the alternator plug/harness are included. Easy assembly was a priority during the entire development of this accessory solution. Color graphical instructions walk you through every step of the ultra-easy installation. Features: Bracketless accessory mounting with ultra-easy assembly Bottom outlet heater hose options for swap application clearance LT1 style hairpin premium 150 amp alternator LT1 style water pump cartidge design Compact SD7 A/C compressor Type II power steering pump with baffled reservoir P/S adapter hardline to AN -6 adapter included Steam tube input port Shortened top outlet nipple for more radiator hose turns and routing room OE pulley ratios for optimal accessory performance No adapters/spacers required! Fits ALL LS engines except with dry sump and/or supercharger. Original belt alignment is not a variable as the water pump and crank pulley are included. Works with all common aftermarket and factory throttle bodies and intakes. Works with VVT applications Works with Hooker turbo manifolds. |
01-07-2018, 06:09 PM | #15 |
Pretty compact footprint.
The belt wrap on the crank and ps pump looks minimal, though I am sure Holley engineered it to work well. Other thoughts? |
