01-08-2018, 05:19 PM | #1 |
battery charger
I am looking to buy a battery charger. I have a car that I only use every couple of weeks and the battery is usually to low to start. I am looking for the best quality for my buck. Any recommendations?
01-08-2018, 08:46 PM | #2 |
Re: battery charger
I have a couple of motorcycles and have an Opti Mate III. I would recommend it. Take a look here, http://optimate1.com/product-categor...ry-charger-en/
01-09-2018, 03:10 PM | #3 |
Re: battery charger
I bought an cheap charger at Harbor Freight. I ended up tossing it and buying a Schumacher. I've been very happy with the way it's performed.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
01-11-2018, 08:08 PM | #4 |
Re: battery charger
I also have been using Schumacher battery Tenders , I have 3 one is 10 years old and the other is 8 the 3d I bought about a year ago because of the same issue as you are having ,newer car and truck have constent current draw 24/7 some more then others , I also found out that some autos need to be locked this puts them in to what is called by the dealer I spoke to (SLEEP MODE) knocking out most of the current draw , My dealer told me after I lock my car it still take 16 minutes for it to go to sleep( minimal current draw) .
01-12-2018, 12:49 AM | #5 |
motor exploder
Re: battery charger
I have one of the Schumacher fully automatic chargers w/100A engine start. it has a 3/5/30 amp charge with auto shut off and will do AGM/gel/regular batteries. It was more expensive than your regular run of the mill charger, but to me it was well worth the money and nearly 5 years, I've had no problems out of it.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
01-12-2018, 03:26 AM | #6 |
Post Whore
Re: battery charger
i use battery tenders on all my stuff
01-13-2018, 01:05 AM | #7 |
Re: battery charger
I'm very happy with this one: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I use Schumacher battery tenders on anything I'm storing as well. |
01-13-2018, 09:25 AM | #8 |
Re: battery charger
x2 battery tenders,got 3 stay plugin all winter
72,2wd short bed cheyenne,350,350trans,air,tilt,tach,posi 373 gears 70 nova 5.3,350 trans 80 z28 350,350,trans,bought new 03 cat. 06 gmc swb ext cab |
01-13-2018, 09:51 AM | #9 |
Re: battery charger
Do you have a NAPA close by? they sell a great charger/maintainer for $25. you can use it on 6v or 12v, you switch it over to your choice. Great item for so little
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
01-13-2018, 05:38 PM | #10 |
Re: battery charger
Thanks everyone for your suggestions
