01-10-2018, 08:32 PM | #1 |
Black Exhaust after long rest
My 71 C20 with the original engine and QJet sat for a few months while I did some metal and paint work.
When I went to restart it I had to prime the fuel pump by dumping fuel down the carb. That worked fine but now my issue is that there is a large amount of black exhaust when it fires and it runs too rich before dying. If I manually open the clutch it will stay running. The truck was running well, was timed and fuel mixture screws were set before resting it for a few months so i'm not sure what happened. I'm certainly no expert in dealing with carbs so I'm sure I'm missing something simple. would appreciate any help |
01-10-2018, 08:47 PM | #2 |
Re: Black Exhaust after long rest
Smack the front of the carb with the plastic handle of a screwdriver a few times.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
01-10-2018, 08:48 PM | #3 |
Who Changed This?
You probably have some dried fuel making the float stick a little, if the choke is opening all the way. Two things to check; choke opening properly would be the first one. If you have a brass float, you could pour a little acetone down the bowl vent tube and let it dissolve some suspected crud. Don't do this if you don't know what your float is made of; I believe that acetone may dissolve the composition float.
01-11-2018, 09:58 AM | #4 |
Either it Dried fuel or Seperated Fuel. The 10% Ethanol fuel Seperates after about 30 days, and will gum up you "old style fuel delivery system". Put about a half tank of clean gas with a can of Sea Foam, and run it. It'll run like crap for a little bit but, it'll clean everything out. If that doesn't work, you're looking at a carb rebuild to fix your issue
01-13-2018, 10:31 PM | #5 |
Thanks guys. Carbs banged and sea foam in with fresh gas. We'll see.
01-23-2018, 11:31 AM | #6 | |
Carb rebuild time? I see QJet rebuild kits all over the place. Is one better than another? Brass or rubber float? |
01-23-2018, 11:51 AM | #7 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
I get my rebuild kits here, https://cliffshighperformance.com/ and here, https://quadrajetparts.com/ As far as the floats go, the new Quadrajet Nitrophyl Carburetor Float Part # [1402] will withstand the riggers of moonshine. (alcohol)
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
01-23-2018, 11:56 AM | #8 | |
Easier to replace the pot. Easy to check the pot too. Draw a little vacuum on it, it should pull in the arm. |
01-23-2018, 12:21 PM | #9 |
01-23-2018, 12:54 PM | #10 |
This could be fun! LOL!!!
On the passenger side of your carb you’ll see a vacuum pot. It has a vacuum hose attached to it. Pull the hose off the pot, use a longer vacuum hose and draw some vacuum on it. Use your lungs for that. The plunger arm on the pot should move inward. If not it needs replaced. That’s the fun part. You get to suck on a nasty tasting vac hose. JK!! If you’re wondering what the vac pot’s use is, I’ll splain it. If your choke is working correctly then thechoke plate closes completely when you open the throttle to start a cold engine. When the motor fires, it creates vacuum. The vacuum pulls on the vac pot and the linkage opens the choke plate about 1/4 inch. Just enough to let your motor run without being too rich. There are adjustments in the linkage to vary the amount of choke plate opening. If you need a longer vac hose sometimes you can use one of the windshield washer hoses. Easy stuff, eh! Last edited by geezer#99; 01-23-2018 at 01:00 PM. |
01-23-2018, 01:59 PM | #11 | |
This is what I needed! Well done! I will try this but I'm pretty sure the plate is partially opened when cranked cold. Isn't this a sign that it is working? Or not necessarily? |
01-23-2018, 03:43 PM | #12 |
01-23-2018, 07:22 PM | #13 |
wow. So I didn't have the port on the vac pot hooked up to vacuum or plugged. Oops. Runs perfectly now. Thanks for the troubleshooting. I owe you a beer
01-23-2018, 07:34 PM | #14 |
Generally it’s always something simple!
