01-11-2018, 11:17 PM | #1 |
72 door problem
I have a 72 cab and the doors that were on the cab were wery rusty well beyond repair. First thought was to buy new doors but decided to find good used ones. Found new good doors so figured life would easy. The problem is the window fram does not fit the cab well at all. When the door is closed the rear gap is to big abd the window frame radius is almost hitti g the cab radius. The door frame gap at the top rear of window frame is good but at the front its better than 1/2 inch. Same problem on the front of door. Lower part of frame is perfect and at the top corner its huge. Any advice on a fix? I do have the original window frames a n d thought about switching them?
01-12-2018, 09:06 AM | #2 |
Re: 72 door problem
Unfortunately, whether OEM or repop, most doors will have to be fitted due to the variances in these old cabs. It should be an easier job though with OEM sheet metal.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-12-2018, 01:06 PM | #3 |
Re: 72 door problem
ttt for ya. subscribed.
i survived cancer and kidney stones, but my kids are killing me. |
01-12-2018, 01:13 PM | #4 |
The Older Generation
Re: 72 door problem
Looks like the window frame is bent where it meets up with the door skin in the front. If you look at it close you can see the curve in it just above the door skin. If you have access to another door to try I would do that before any major surgery on anything..... Are you sure that isn't an aftermarket door? LockDoc
01-12-2018, 01:21 PM | #5 | |
Re: 72 door problem
01-12-2018, 02:02 PM | #6 | |
Re: 72 door problem
01-12-2018, 03:02 PM | #7 | |
Re: 72 door problem
Along the front, we actually added metal to the door frame to correct the gaps to the cab. A lot of work, but gaps are nearly perfect now. I posted a picture several weeks ago. Nearly all doors will need work to make them right, whether original or aftermarket. Good Luck!! |
