Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 01-12-2018, 01:40 PM   #1
Llay R. Rac
Llay R. Rac's Avatar
upper gate weight
i have new weatherstrips for my upper and lower end gates.
i am thinking of pulling the upper gate off the truck to install the weatherstrip, seems like it would be a lot easier/neater to install/glue the strip.
I wonder if i can remove/reinstall the gate by my self, what does it weigh?
anyone have any tips for doing weatherstrip on endgates, i did my side doors weatherstrip a few months ago so i have some recent experience with glue on weather strips.
1965 Suburban, 2 wd.,292, 4-speed.
proudly owned and operated since Valentines day 1969.
Llay R. Rac is offline   Reply With Quote
Old 01-12-2018, 08:27 PM   #2
pimpston65
pimpston65's Avatar
Re: upper gate weight
not so much heavy, just long. i've placed mine on and off by myself without issues. 2 people would be best for bolt alinment...
pimpston65 is offline   Reply With Quote
Old 01-12-2018, 10:10 PM   #3
65chevysub
65chevysub's Avatar
Its funny you brought that up. Im pulling mine off tomorrow to finish sanding and repainting the inside of my top door. Length as mentioned will be the big issue. If you need help, let me know and I will come over. Ive also got the single master cylinder and front brakeline for you
65chevysub is offline   Reply With Quote
Old 01-12-2018, 11:24 PM   #4
Llay R. Rac
I went and did the weatherstrip with the gate on. I got a little messy but not bad.
I found one of my hinges has some up and down slop, so I'll need to replace that to get a good seal.
pimpston65 or 65chevysub, do you know the size of the clutch head for the bolts that go into the top of the gate?
Old 01-13-2018, 12:25 AM   #5
65chevysub
65chevysub's Avatar
No info on size of clutch head bolts. When you get them out you might want to change to a standard bolt if possible.
