Old 01-15-2018, 12:54 PM   #1
russellrox
66 c10 Ls harness routing
I am trying to figure out the best way to get my ls swap harness from the cab to the engine bay to look clean. I want to see some ideas on if it’s best to mount Ecm under the dash and pass through the firewall. Or if it’s easier to put it under the seat and run under the cab. I don’t really want to cut my new Nelson performance harness to extend it if I don’t have to.
russellrox is offline   Reply With Quote
Old 01-15-2018, 01:30 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 66 c10 Ls harness routing
Did you get them to extend it from stock length?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-15-2018, 01:51 PM   #3
sprint_9
sprint_9's Avatar
Im running mine down the back of the motor and up through the floor. The main determining factor, like Clyde has mentioned, will be length.
I was planning on going through the firewall on mine, but I had too much length and would have had a coiled mess. Running up through the floor uses up that length and keeps the hole out of sight.
sprint_9 is offline   Reply With Quote
Old 01-15-2018, 03:11 PM   #4
russellrox
Any pictures of where to locate the hole and how it was ran?
Old 01-15-2018, 05:39 PM   #5
russellrox
Old 01-15-2018, 07:42 PM   #6
sprint_9
sprint_9's Avatar
I haven't ran my wiring yet, just mocked up. I picked a place on the floor that I thought would be clear of my seat mounts and leave room to mount the ecm on a flat surface while being under my seats out of view with enough wire to comfortably reach everything. The other thing to consider if you run it this way are things like exhaust, the driveshaft, and places to secure the harness in order to keep it away from those items.
