Old 01-21-2018, 09:23 AM   #1
krue
Designated A-hole!
krue's Avatar
4l80E questions
I have an '03 GMC van with 6.0l and 4l80E for swap purposes. The van was a Dept. of Corrections van and they had been using it for parts. It has no gage panel so I can't tell what gear the tranny is indicating. That matters because the tranny is in limp mode (only 2nd and R) and I am trying to figure out why before I pull it. There is tranny fluid in the round connector and some sources say that could be the problem and others say not. The plug does have power to it with the key on. What should I be looking for? Replace the harness? If so where is the best source for replacement.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 01-21-2018, 09:25 AM   #2
Bigdav160
Bigdav160's Avatar
Re: 4l80E questions
You need to read the trouble codes. It sounds like an electrical problem and trans fluid in the connector is a problem.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-21-2018, 09:50 AM   #3
krue
Designated A-hole!
krue's Avatar
Re: 4l80E questions
Only code it shows is a temp. sensor voltage, don't remember the number off the top of my head.
www.daveramsey.com
Old 01-23-2018, 03:32 AM   #4
krue
Designated A-hole!
krue's Avatar
Re: 4l80E questions
Anyone else?
www.daveramsey.com
Old 01-23-2018, 03:42 AM   #5
ls1nova71
ls1nova71's Avatar
Re: 4l80E questions
Limp mode is 2nd and 3rd, but if you say it doesnt have power going to it when the key is on, then you need to figure that out since that's probably the problem. Check all the fuses.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-23-2018, 07:54 AM   #6
krue
Designated A-hole!
krue's Avatar
Re: 4l80E questions
The plug does have power with the key on.
www.daveramsey.com
Old 01-23-2018, 01:10 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 4l80E questions
Depends on what scanner your using. Most regular scanners will show regular DTC trouble codes (P codes). A Tech2/3 or reading via HPT Ecm scanner will show you the extended codes (T, U and BCM codes), and it will also show gears.
I'll have to check back through some of Clinebargers posts, he's the resident trans expert and has previously posted his preferred sources for trans harnesses.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-23-2018, 08:28 PM   #8
krue
Designated A-hole!
krue's Avatar
Re: 4l80E questions
Thanks, will do.
www.daveramsey.com
