Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 01-23-2018, 07:21 AM   #1
Gokart Mozart
C50 dimensions
What are the dimensions of a C50? How much bigger are they from c10s? Looking at 67-72 specifically. Thanks in advance.
Gokart Mozart is offline   Reply With Quote
Old 08-26-2019, 03:39 PM   #2
jablack
Classic Chevy Recycler
jablack's Avatar
Re: C50 dimensions
I would like some info myself
2004 Chevrolet Trailblazer EXT
1970 Chevrolet C50
1979 Chevrolet C30
Need another 67 or 68 soon...
jablack is offline   Reply With Quote
Old 08-26-2019, 07:11 PM   #3
txagincali
Re: C50 dimensions
What dimensions are you looking for in particular? Everything varies or are the same.
Wheelbases range from short to looooong and anywhere inbetween. 2 chassis I have though are 127" wheelbase, same as longbed C20, but one has 2 feet of extra frame out back and another has 6' of frame out back. Run a flat or dump bed, wheelbase and frame length could stick way out there.
Frames are heavier but widths are similar since the cabs mount to the same widths.
Cabs are the same except for the firewall and toe boards up front that account for the inner wheel wells.
Doors are the same except with the front most cut out for the inner wheel wells.
Windshield and side windows are the same as a truck.
Small back windows similar to 67's I believe.
Etc Etc. What are you looking for to compare?
1963 Olson Grumman Bread Van - Possible Suburban Swap (sporadically worked on to strip paint)
1969 GMC C10 Pickup SWB Stepside (heart transplant)
1969 Chevy C50 Fire Truck converted to Utility Truck being built into Pickup Truck (newest addition, accumulating spare parts)
1972 GMC K5 Blazer 4x4 (sporadically being worked on, accumulating parts)
txagincali is offline   Reply With Quote
Old 08-26-2019, 07:15 PM   #4
jablack
jablack's Avatar
Re: C50 dimensions
Width. I bought a C50 and need to tow it on a trailer. I didn’t have a tape with me when I bought it. It has the smaller fenders. Just want to make sure I bring enough trailer with me..
1970 Chevrolet C50
1979 Chevrolet C30
Old 08-26-2019, 07:36 PM   #5
txagincali
Re: C50 dimensions
Ooof yea hopefully you have a full flat bed (no fender wells, or at least very low fender wells).
My 1 chassis I have here (No body but add 1.5" to each side I'd say and only single wheels installed on the rear dually axle)
Front wheel width at the tires: 78"
Front wheel width at the lugs: 84"
Rear wheel width at the tires: ~88" (maybe someone else can confirm this)
Like I said my rear axle only has 2 wheels on it which helped to narrow it greatly and helped with loading on my regular car hauler trailer. My other truck I had to hire out to a guy with a winch and a hydraulic flat bed. The width wasn't the biggest concern there, it was more of the weight.
Old 08-26-2019, 07:39 PM   #6
CarolinaHD
Moderator
CarolinaHD's Avatar
Re: C50 dimensions
I only measured rear tire width but got 88" outside as well.
The other measurements sound right.
Alex
1967 C50 292ci Lumber truck
1967 C50 292ci Dump truck
1967 C60 366ci Fire truck
CarolinaHD is offline   Reply With Quote
Old 08-26-2019, 07:48 PM   #7
jablack
jablack's Avatar
Re: C50 dimensions
Thanks for the information.. I may end up flat towing it.
1970 Chevrolet C50
1979 Chevrolet C30
Old 08-26-2019, 09:41 PM   #8
jablack
jablack's Avatar
Re: C50 dimensions
Any idea how much one weighs? It’s a flat bed non dump, 14 to 16 foot wheelbase I’m guessing..
1970 Chevrolet C50
1979 Chevrolet C30
Old 08-26-2019, 10:01 PM   #9
CarolinaHD
Moderator
CarolinaHD's Avatar
Re: C50 dimensions
Around 8000lbs, more if it's a steel bed.
Alex
Old 08-26-2019, 11:46 PM   #10
68BlueBeast
Re: C50 dimensions
Mine was ~9500 lbs when I rolled it over the scales leaving the dump last year if I remember correctly. I have a 179" wheelbase and a dump bed with all the associated hydraulics.
68BlueBeast is offline   Reply With Quote
Old 08-27-2019, 03:22 AM   #11
Pvmt-Pndr
Re: C50 dimensions
Mine is about as light as they come and my registration says she's 8520
Pvmt-Pndr is offline   Reply With Quote
Old 08-27-2019, 07:43 AM   #12
Nobighurry
Re: C50 dimensions
I have a 167" wheelbase big block steel flat dump and it is 10700# empty.
Nobighurry is offline   Reply With Quote
