01-23-2018, 10:41 AM | #1 |
Big Block Exhaust shield location ?
Can any provide pictures or measurements for the bolt holes to locate the big block exhaust shield that goes against the underside of the front right floorboard? I am adding the shield and my truck has no marks or dimples in that area at all.
1968 SWB Step Side, Big Block, 4L80E , Running! |
01-23-2018, 11:19 AM | #2 | |
The Older Generation
Re: Big Block Exhaust shield location ?
LockDoc
01-23-2018, 11:33 AM | #3 |
Did a search and found pictures. Don't think mine has any dimples. Need to look some more.
01-23-2018, 01:59 PM | #4 | |
I went out and took pictures with my phone. When I try to transfer them to my computer it says it can't find a compatible program on my computer to transfer them. Go figure. The last time I did it it transferred them with no problem. My phone has updated to a newer OS since then so that must be the problem. I'm smart phone illiterate.... Anyway, I can tell you that the holes are 1 inch and 5 3/4 inches from the seam below them. LockDoc
01-23-2018, 03:55 PM | #5 |
Thank you very much!
01-23-2018, 04:24 PM | #6 |
No problem. If I figure out how to get the pictures transferred I will go ahead and post them here for future reference.
LockDoc
03-07-2023, 11:11 PM | #7 |
Active Member
Bringing back on old thread. I have a 1970 factory BBC truck that does not have the heat shield and I can't find the dimples. Understand they are 1 inch and 5 1/2 inches from the seam. How far are they located from the tunnel?
03-08-2023, 01:19 AM | #8 | |
I don't have that cab anymore so I can't check for you but someone should have one..... This is the best I can do. LockDoc
03-08-2023, 04:14 PM | #9 |
Active Member
Sir,
Thanks for the picture. That along with the distance from the seam will likely get me close enough. Thanks Rob |
03-08-2023, 05:41 PM | #10 | |
No problem Rob. LockDoc '
