Old 01-27-2018, 11:37 AM   #1
Flubyu
Connecting factory power steering
So I know there is server ways I’m sure to connect the factory steering gear to the factory LS pump. I just wanted to start this thread for others and myself whom are on a budget and want to utilize the factory components as much as possible. Parts and pics would be great. Thanks all.
'71 C-10 SWB Shop Truck
Currently 350/350, soon to be LS'd.
Flubyu is offline   Reply With Quote
Old 01-27-2018, 01:05 PM   #2
ls1nova71
ls1nova71's Avatar
Re: Connecting factory power steering
If you're using a truck LS power steering pump, its super simple. Just take out the flow control valve from your original pump and put it in the newer pump. It's the big 1" fitting at the back of the pump where the high pressure line attaches. Then simply use your factory hoses. Done.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-27-2018, 01:10 PM   #3
Flubyu
Wow. That seems too easy!
Almost like these trucks were destined to have LS POWA!!
Old 01-27-2018, 02:54 PM   #4
Flubyu
Is there a source to buy the fittings rather than pulling them out of the original pump? I have my complete engine sold so I hate to not leave the fitting in the pump for the next guy...
Old 02-04-2018, 09:04 PM   #5
85burb
85burb's Avatar
I have never done anything other then just screw the original truck line into the pump. Never even knew there was a flow control valve.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 02-04-2018, 09:34 PM   #6
mongocanfly
Post Whore
mongocanfly's Avatar
on my 81 my truck hoses fit the LS pump...all I did was hookem up..both were metric....it won't work if you have standard fittings and metric though....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-04-2018, 11:20 PM   #7
Daaaanz67
I went to my local ATI auto parts and custom built my own line. That parts store is now Reibes auto parts in my area so check there. I don’t have the fittings size. I used a higher pressure hydrolic hose. That was five years ago and no leaks. The down side is if anything happens while on the road you’ll probably will not be able to have one made. Wish I would have went the route everyone is talking about.
Daaaanz67 is offline   Reply With Quote
Old 02-05-2018, 01:20 AM   #8
dayj1
The SAE pump fitting has 5/8-18 thread. The metric fitting is M16 x 1.5. That's close enough that they'll interchange as far as threading into each other. For the seat, you can convert from metric o-ring to 45* inverted flare with "Factory Air" part number 16746 which come in a box of 2 at your local Advance auto for 16746 for about $3.50. It simply pushes into the metric fitting by hand.
If you have money to burn, Speedway sells the same thing for $9 plus shipping (for a single fitting instead of 2). But they have a neat video that shows what to do with the fitting at about the 1:20 mark.
https://www.speedwaymotors.com/O-Rin...ter,24682.html
dayj1 is offline   Reply With Quote
Old 02-08-2018, 06:43 PM   #9
Flubyu
Found this for guys like me that don't have a steering pump to rob the fitting out of:
https://www.dirtydingo.com/shop/prod...oducts_id=1414
