fuel pump and tank
this is a fellcellguys tank(I think that is his name)tank is for carb.now going to fi ,tank is 8 1/2 ins. deep, what is the best intank pump and ring to use(2000 5.3) would it matter where i put it,i was thinking middle,i have ask a few question and you guys have help a lot,this is my first swap,i will more than likely have some more,thanks very much
72,2wd short bed cheyenne,350,350trans,air,tilt,tach,posi 373 gears 70 nova 5.3,350 trans 80 z28 350,350,trans,bought new 03 cat. 06 gmc swb ext cab |
Re: fuel pump and tank
Why modify your tank? Just use an inline high pressure fuel pump mounted inside the frame rail with an inline fuel filter... then you're all set with minimal fuss.
**RED SEAL CERTIFIED JOURNEYMAN SINCE 1993** My 1966 GMC Value Van Project 1951 GMC 9430 1-Ton I'm just going to put an OUT-OF-ORDER sign on my forehead... and call it a day. |
#4 | |
I got one walbro 225 I think when I first started this swap,had to drop tank to put in return line, thought now would be good time for in tank pump.i don't no this is my first swap,trying to do the best first time around and hopefully not have to worry about it
Post Whore
![]() ![]() Join Date: May 2015
nothing wrong with a intank or inline pump...both do the same job...if you've already got a walbro and vett filter/reg I'd just go with that..I've been running one in mine for years with no issues....
Post Whore
this may be similar to what your looking for.....
http://www.gearhead-efi.com/gm-ecm-p...onversion.html
I think i'll just go inline ,want to thank all you guys for info
#9 | |
#10 | |
![]() I would do an in tank pump any day over an inline pump if I had an option. |
ol well
I was thinking the exact same thing.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
#13 |
maybe I should have said GOOD WAY
#14 |
I would go in tank too, from a reliability stand point, and the fact that your tank isn't baffeled at all. When the tank gets low, that electric fuel pump pushing the fuel to the engine at 58 psi, is going to starve for fuel during acceleration and cornering. On a carb'd engine you don't notice it because the fuel bowls hold enough fuel for the pump to catch up, but on an EFI engine, the stumble will be instantaneous. With a tank like you have, I would use a factory sender/fuel bucket type pump, that way you always have fuel at the pump. You can either buy something like a Vettworks adapter or make one since they're not very complex, then get a pump from a truck that matches the depth of your tank, Tahoe's are shorter than Silverados. http://www.vetteworksonline.net/cata...qln9hmmunf50v5
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#15 | |
#16 |
This is the last one I did, it's on a 59 Chevy, but same idea. You probably wouldn't need to recess the tank on a truck like I had to do. https://ls1tech.com/forums/conversio...r-wagon-5.html Tank mods start at about post 94.
#17 |
I use this in my truck. It uses a 5th gen camaro fuel pump module.
https://www.vaporworx.com/ https://www.vaporworx.com/product-ca...ounting-rings/ and I'm assuming your tank is not baffled, use these too. https://www.vaporworx.com/product/cptkit/ |
#18 |
i talk to dan at vettworks and he's going to try to find me a aluminum ring,his was ss my tank is aluminum if he can't i'll make on , thanks ls1 and raic65
#19 |
No problem Novafrog. Just so you know Vaporworx has an aluminum ring you can weld to your tank. A little pricer, but the pump setup you will use no longer needs an external regulator. You'll only run a feed line to the engine. The regulator is housed in the fuel pump module.
#20 | |
#21 |
Post Whore
you can get fuel grade rubber caps....or just use it as a extra tank vent..
#22 | |
I personally do not care for the whole blocking off the return line thing, to me its a car fire waiting to happen. I would get a pump with a return and run it like factory since your engine is set up for a return. High pressure fuel systems really aren't the place to cut corners to make things appear easier....
#23 |
This is another reason I dont like blocking the return line. I'm pretty sure he's talking about the line on the rail, and a little miscommunication going on here. If someone tried to use these on the rail, it would only be a matter of when, not if there will be a fire.
#24 | |
#25 | |
