![]() Join Date: Feb 2014
Hydroboost question
I am putting hydroboost on my 65 c10 I have a 6.0 out of a Pontiac G8 which is the same as the Camaro the power steering pump has a banjo fitting the steering box has a flared fitting the hydroboost has O rings any suggestions on where to get my hoses thanks Doug
Post Whore
![]() ![]() Join Date: May 2015
Re: Hydroboost question
....you may have to get custom hoses made if your going from metric to sae to o-ring to whatever...a good hyd hose shop can fix you up
meowMEOWmeowMEOW
the Parker Store is in tons of states and will do swaged hoses with most ends if you know the sizes. I used hose ends from a company called Edelmen to flare and change the fitting ends when I did my hydroboost swap.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#5 | |
