02-05-2018, 02:21 PM | #1 |
Floor pan rust repair
I'm getting ready to replace the sections of my floorpan toe boards shown in the pics below. I plan to make my own patch panels. I'm just wondering if anyone has an tips/tricks that I should be aware of before I go cutting out the swiss cheese. Any warnings about these areas? Thanks.
http://67-72chevytrucks.com/gallery/...n-rust&cat=500 http://67-72chevytrucks.com/gallery/...n-rust&cat=500 Couldn't get the pics to embed into the post. Click the links to see what I'm replacing. Sorry.
Just because you can, doesn't necessarily mean you should. 1959 3100 stepside 355 + T5 Last edited by agnes the dog; 02-05-2018 at 02:22 PM. Reason: added links |
02-05-2018, 02:45 PM | #2 |
Post Whore
Re: Floor pan rust repair
here ya go.....
02-05-2018, 02:49 PM | #3 |
Post Whore
depending on how bad and how far the rust goes I would weld some cross bracing in there to hold everything in place before you start cutting...but what im seeing isnt bad enough for bracing though.....what's in your pics is fairly common with these ol trucks....when you get those places cut out use a rust nuetralizer in that area...
02-05-2018, 03:07 PM | #4 | |
Just because you can, doesn't necessarily mean you should. 1959 3100 stepside 355 + T5 |
02-05-2018, 03:11 PM | #5 |
^^^^^^^^^^ Just what I was thinking.
From experience on mine that wasn't necessarily good It is very important to make sure you have the cab sitting level be it on or off the frame, you wan to get your door gaps set before you weld anything and the bracing helps keep things from moving when you start cutting and then welding. I didn't think to set the door gaps on my truck before doing some modifications and lots of welding and then fought door gaps from then on. If the cab isn't all level and square you stand a chance of building in an issue that it may not have had before after it is stiffer from the new metal being welded in. Other than that, take your time plan it out and do a nice neat and orderly job that you will be proud to show the results of to us. The "I am going to do this the best I can do it" Beats out " I gotta get this much done today or else" every time.
02-05-2018, 04:27 PM | #6 |
If you're leaving the cab on the frame during the rust repair process.... I've heard of people using 2x4's as kick stands on the firewall to help keep the cab where it needs to be.
02-05-2018, 07:28 PM | #7 | |
02-05-2018, 07:29 PM | #8 | |
Thanks for all the replies and ideas.
02-05-2018, 07:30 PM | #9 |
Thank you! If you don't mind, how did you get that to work?
02-05-2018, 11:26 PM | #10 |
Post Whore
I just copies and saved your pics...and then posted them like this...
http://67-72chevytrucks.com/vboard/s...sting+pictures
02-05-2018, 11:29 PM | #11 |
Post Whore
those rotted support areas are possibly why your constantly fighting your door gaps....it would be a much easier repair with the cab off so you can get to everything. ...but your gonna have to get the cab weight off that area while you repair it...when you get the cab weight off that area your door gaps may move again so be sure and check for that before you cut but after you jack it up...you can weld bracing in the door opening where the door will still open and close...
02-06-2018, 11:12 AM | #12 |
I did a very similar repair in the same places. Cut out the support under the floor first and welded in a new one. Cross bracing is a great idea. I probably should have done that but I got lucky with the small amount I replaced. The passenger side had the battery box hole for me. That was probably the trickiest place to do. As for the side kick panel, I ended up buying the patch panel for that area just because it has a few nuances to the way its bent into place. Glad I did.
While I was in there, I also sprayed the back side of the outer skin with some POR15 just to try and seal it up a bit and prevent future rust through. Probably should have used clecos for this part but I was a newbie at the time and didn't know what those clamps were for
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
02-06-2018, 07:16 PM | #13 |
Sorry, I didn't see this comment yesterday. Such great advice! I've always been results driven and try to have a goal to get stuff done. I have to get better at taking my time!
02-06-2018, 07:21 PM | #14 |
Well, I broke down and ordered some rocker/steps today. While I was at it, I got the repair patch panels for the floor. Probably will save me a lot of time and frustration. Hope to have them by the weekend. I'll post pics when I get it done. Thanks for all the support.
02-07-2018, 03:58 PM | #15 |
+1 on the bracing. I thought I had mine braced well enough:
Now I'm having a hell of a time getting the doors back on... Last edited by b-mac; 03-06-2018 at 01:25 PM. |
02-07-2018, 05:49 PM | #16 | |
top, bottom or rear door gaps are worn hinges or rusty hinge pockets front cab mounts are ~1'' thick rubber and mounted to allow the frame to flex the rear cab mounts are .1'' thick at most plus shims to adjust the front door gap the big cross member under the bell housing supports the front cab mounts if you cut it out to install an automatic you need to add some bracing to support the cab mounts you can see how i braced the cab supports in my build thread (using chrome and the add-on) there are braces built into the floor board extending from the step to the trans cover that need to be made whole again these keep the floor from flexing and are welded to the floor
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
03-06-2018, 11:18 AM | #17 |
Here's the final product. The passenger side welds are much better than the driver side. Practice helps! It's going to be covered with sound mat and carpet anyway.
