Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-27-2018, 03:32 PM   #1
nikwho
nikwho's Avatar
Sources for nitrous oxide in AZ?
Hello all,
I've got my new nitrous oxide system (Nitrous Express Mainline 1000) all plumbed and ready to go. I've got it set up on a WOT switch, that's also connected to my MSD Digital 6+ ignition box. Anyway, I'm looking to get a bottle filled and having a really hard time finding a shop that can fill it. I live in Flagstaff, which has nothing. I've also looked in Phoenix and Kingman with no luck. Anyone have a source?
Thanks,
Nik
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 03-01-2018, 10:30 AM   #2
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Sources for nitrous oxide in AZ?
I cant give you a source , but I will suggest putting a -4 bottle nut on the new bottle and using a air conditioning vacuum pump to pull the air out of the bottle prior to filling it . This way its pure N20.
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 03-01-2018, 11:45 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
FWIW the Nitrous situation got fubar'd last season because of the processing plant explosion and Airgas basically not having a commercial nitrous source....so its slowly starting to return, but its taking a while to trickle back down.
You can't get your tanks filled at the larger Airgas distributors, but you may be able to buy a larger K-tank of it if you have access to a fill/transfer station. We just started getting Nitrous back in the Mil/Chi area, but its still harder to find walk-in tank fills (and the price is still inflated a bit).
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
