03-01-2018, 03:15 AM | #1 |
POL 8-Lug Disc Brakes, Reuse 1970 Center Link??
I'm about ready to convert my 1970 to front disc brakes and got all my parts on the table, but realized that the kit assumes I'd reuse my existing center link...is this correct?
A few backup articles making me have this question: LoLife's Comment #3 Another LoLife comment making me question, comment #2 Here's the kit I purchased: POL 8 LUG DISC CONVERSION Any insight would be appreciated.
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
03-01-2018, 09:25 AM | #2 |
Re: POL 8-Lug Disc Brakes, Reuse 1970 Center Link??
One nice thing about buying a kit is that you have the vendor as a resource. I would ask POL as they should be the expert with their kit.
03-01-2018, 12:16 PM | #3 | |
67-72 parts collector,…
So I assume you will use your original centerlink. The kit says uses 71-72 tie rods, so I suspect it used a 71-72 spindles. Without seeing the kit, I bet the inner tie rods are a 63-70 version.
03-01-2018, 12:38 PM | #4 | ||
Lastly, thank you to the forum. Never want to be a burden and appreciate the help.
03-05-2018, 09:19 PM | #5 |
Junior Member
Hey Jahloha. Yes, you will retain and use your factory center link. When you called here, did you speak with someone? If so, who? I would like to find out why you still have not received and answer. Thank you for your order.
--JC
Thank you, Performance Online www.performanceonline.com info@performanceonline.com https://www.facebook.com/PerformanceOnlineInc |
03-06-2018, 12:18 AM | #6 |
Who Changed This?
Hmm. That's a lot better response than I got about missing and damaged parts when I bought my kit from POL. I got crickets. You must have changed ownership or something.
03-06-2018, 04:56 AM | #7 | |
Dang bro, that sounds sucky. Sorry that happened.
