03-04-2018, 10:21 PM | #1 |
another disc brake conversion question
Was wondering if anyone has found a complete disc brake conversion kit that has, 2" drop spindles, rotor/caliper all the hardware that doesn't make the wheel stickout further? Also would like a lowering kit that's has everything complete.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
03-04-2018, 10:33 PM | #2 |
Re: another disc brake conversion question
Im in to see what you find .
03-04-2018, 10:58 PM | #3 |
Started to order a kit a couple days ago, and noticed it said makes the wheel stick out further. Thought someone might have overcome this problem.
03-04-2018, 11:21 PM | #4 |
I thought CPP has a kit that does not alter the stance
03-04-2018, 11:33 PM | #5 |
03-05-2018, 08:28 AM | #6 |
I'll check them out, thank you for the information
03-05-2018, 12:47 PM | #7 | |
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
03-05-2018, 10:35 PM | #8 |
The last response brings up another question, what bolt pattern is Chevy truck? I figured seems its Chevy half ton it would be 5x5 3/4. I know not all are, even now but what the heck is it?
03-06-2018, 09:45 AM | #9 |
5 on 5 for GM 2wd trucks and vans from 71 up to the early 90s
Big GM cars are that pattern from the 60s to the 80s Also big Ford & Lincoln cars through out the 70s. Lots of possibilities for 9” rears if you want to go thru the work to swap one.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
03-06-2018, 09:49 AM | #10 |
Good to know thank you
03-07-2018, 09:19 PM | #11 |
Just purchased this day before yesterday.
https://www.azproperformance.com/Pro...liper-C10.html This kit comes with 2 1/2" lowering spindles though. Not sure if that is optional. Last edited by jbice70gmc; 03-07-2018 at 09:28 PM. |
