03-05-2018, 12:10 AM | #1 |
Throttle linkage
I need the linkage and return spring that connects the floor peddle to the carburetor. I looked at Summit and, there are so many different ones I have no idea which one I need. Could someone please head me in the right direction? Thanks in advance for any help.
03-05-2018, 12:32 AM | #2 |
60-66 Nut
Re: Throttle linkage
What year of truck and what engine?
03-05-2018, 04:15 PM | #3 |
'65c10 with 383 stroker. Below is pic of carb and part of throttle in engine bay.
03-05-2018, 05:22 PM | #4 |
I have used threaded rod with two heim joints. That worked pretty well.
03-05-2018, 05:23 PM | #5 |
I used threaded rod wit 2 heim joints. That worked pretty well.
03-05-2018, 06:27 PM | #6 |
The swedged aluminum throttle linkage rod from Speedway (in black or Aluminum color) makes for a very tidy and sturdy linkage setup, don't forget the right hand and left hand heim joints for each end.
https://www.speedwaymotors.com/Swedg...read,3944.html This swedged throttle linkage tubing is tapped 3/16" (10-32) LH and RH thread. One end of the throttle rod will have left hand threads, and the other end will have right hand threads. Made of 5/16" x 0.049 round aluminum tubing. Note: When measuring for your tube length, you will want to allow 1.5" in length for the rod ends (3/4" of length for each end when calculating your eye-to-eye measurement. For instance, an eye-to-eye length of 11.5" would require a 10" swedged tube.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
03-05-2018, 07:25 PM | #7 |
This is how I did mine. I used the original rod.
03-05-2018, 08:08 PM | #8 |
03-05-2018, 08:09 PM | #9 |
03-05-2018, 10:15 PM | #10 |
Let me look. If I have one- you are welcome to it.
03-05-2018, 10:54 PM | #11 |
03-05-2018, 11:08 PM | #12 | |
But Found Her 25yrs Later!
My 65 has the original linkage.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
03-06-2018, 12:29 AM | #13 |
60-66 Nut
You are also going to need the bushing and sleeve that goes in the large hole in the throttle arm on the carb.
https://www.summitracing.com/search?...ord=HLY-26-103
03-06-2018, 12:14 PM | #14 |
Ok, thanks, Captain!
03-06-2018, 12:41 PM | #15 |
I just did mine and used a 12 inch 3/16 throttle rod form e-bay that had the ends and bolted one to the carb and the other to the accelerator bracket and adjusted. It seem to work great.
03-10-2018, 03:44 PM | #16 |
Going to over where my part trucks are this afternoon to check.
03-10-2018, 04:24 PM | #17 |
This is where I found my parts
https://www.classicparts.com/1947-72...ctinfo/89-523/ https://www.classicparts.com/1960-66...ctinfo/89-527/ |
03-10-2018, 05:28 PM | #18 |
03-11-2018, 12:39 AM | #19 |
PM sent
03-11-2018, 08:37 PM | #20 |
I made my own.
