03-05-2018, 05:01 PM | #1 |
Bench seat
Hey all in the midst of working on my bench seat trying to remove the back from the bottom. Sprayed the 4 big phillips head screws down and still cant break them loose any tips to remove them?
03-05-2018, 05:11 PM | #2 |
Moderator
Re: Bench seat
Use a Phillips socket and ratchet, otherwise you will strip the screw heads. You will never generate enough torque with a screwdriver.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
03-05-2018, 05:28 PM | #3 |
Re: Bench seat
I have found the Impact Driver tool pretty handy in situations like this. Can't say I had to do my seats that way, but it'll do the trick. Here's a link to the craftsman version...
http://www.sears.com/craftsman-impac...FRy9TwodfzUAcQ
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
03-05-2018, 05:46 PM | #4 |
Re: Bench seat
Thanks Ill head to the hardware store and track one down.
03-06-2018, 11:16 PM | #5 |
Re: Bench seat
Soak in penetrating oil and use a little heat with a propane torch first. Then the impact driver should do the trick.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
03-07-2018, 09:57 AM | #6 |
Re: Bench seat
let them soak in penetrating oil over night. get big screwdriver and tap them good with hammer. try to tighten and loosen.
03-07-2018, 10:29 AM | #7 |
Re: Bench seat
I 2nd the impact driver.
