Old 03-09-2018, 12:15 PM   #1
PGG
How do you confirm matching numbers on a 72 k5?
Thanks PG
PGG is offline   Reply With Quote
Old 03-09-2018, 12:23 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: How do you confirm matching numbers on a 72 k5?
You don’t
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 03-09-2018, 04:13 PM   #3
PGG
Originally Posted by leddzepp View Post
You don’t
Well sh*t really is there not a simple way?
Old 03-09-2018, 05:10 PM   #4
too much stuff
Roadtrip!
too much stuff's Avatar
All you can do is break down build dates and date codes on your components and see if things match up in sequence.
You can match the frame to the VIN and the glove box door...(if the glove box door spid isn't a repro or missing)
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 03-09-2018, 06:14 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here are code examples from my Blazer: http://67-72chevytrucks.com/vboard/s...8&postcount=60
I believe the protect-o-plate also has the engine code embossed onto it.
Old 03-09-2018, 06:36 PM   #6
PGG
What does block # VE112832 mean?
I can't figure this out sorry. Stupid me. PG
Old 03-11-2018, 08:02 AM   #7
PGG
Anyone?
Old 03-11-2018, 09:20 AM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Is a three letter suffix code present? See here for decoding info: http://www.nastyz28.com/sbchevy/sblock.html
Old 03-11-2018, 10:24 AM   #9
PGG
I will go double check tomorrow but I think there is not one.
What does that mean?
Old 03-11-2018, 11:22 AM   #10
DeadheadNM
Carpe manana
DeadheadNM's Avatar
If original it will have a suffix code. Not sure if applicable in your instance or not but per that same website linked above:
"VF292800 - is an example of a over the counter crate engine. "2800" is the last 4 digits of the GM part # for the crate engine assembly. The final digit could be a year code.
Another example: A Targetmaster engine (p/n 14009800) built in 1985 could have a code stamped as follows:
A0198005 (A = january, 01, 9800 = pn, 5 = 1985)."
My green Blazer has a warranty replacement motor/block with a code that begins with "CE..." for counter exchange
Old 03-12-2018, 12:32 PM   #11
PGG
Old 03-12-2018, 12:33 PM   #12
PGG
Its a 4 bolt main and those are all the stampings I could find. Thanks PG
Old 03-12-2018, 12:47 PM   #13
PGG
I a told its a 77-78 block stamping so it must have been replaced. That sucks since I was told it was original.
Now do I rebuild this or do a LS swap since its way off anyway?
PG
Old 03-12-2018, 12:54 PM   #14
Bigdav160
Bigdav160's Avatar
You're right, that block casting is a late 70's 350. The stamping Deadhead is referring to is in front of the right cylinder head, just above the water pump mounting. He has a good pic in his link. You never know it could be a "Corvette" engine
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-12-2018, 11:01 PM   #15
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Free from the albatross of an original motor might as well go LS IMO with an OD transmission.
