03-11-2018, 11:40 PM | #1 |
Metal in oil
I have changed my oil twice once in sept the oil plug was covered in super fine shavings, I know some is normal. When I changed it last weekend the oil plug again was covered in shavings and you could even see it in the oil. I know something is bad, could it be the oil pump? I have run about 20 psi when its cold and it will go past 40 it high rpms, but around valentines day i actually had the display say low oil pressure and ran really low, I stopped checked the oil and it was only 1/4 of a quart low. i restarted it and it was showing more pressure. it has just over 235,000 miles and runs good i have a picture of the oil shown
03-12-2018, 07:39 AM | #2 |
Re: Metal in oil
Most likely a main or rod bearing giving up . You cant keep driving it and expect it to get better . That metal is traveling the motor . Good chance it will leave you somewhere so now is the time to plan .
Either take it out and see what is wrong and repair ( engine will have to come completely apart to clear the metal ) or get a pull out to replace it with . Either way dont ignore it . Do your planning while you still have time . |
03-12-2018, 08:13 PM | #3 |
driving is in my blood
Re: Metal in oil
40psi of oil pressure at 5000rpm is at least 10psi too low.
Throw some 20-50 in while you save up for rebuild. Might work, might blow up just as quick. Its a gamble if you dont take apart to diag.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
03-15-2018, 08:38 PM | #4 |
Re: Metal in oil
Yeah at times when I pass someone the oil pressure will hit 50psi and other times be lucky to hit 40psi
04-22-2018, 09:51 PM | #5 | |
Re: Metal in oil
So the oil pickup tube has an O-ring that will develop cracks over time. When this happens the oil becomes aerated and begins losing oil pressure intermittently. There are a couple tell tale signs. PM for more info. Dan
Forgive my typos, big fingers and little Android digital keyboard....what a mess 06 GMC Sierra crew cab Z71 DD leveling kit, 34's, bumper, LED lighting. Still doing stuff to it. 67 El Camino Custom 300 Deluxe. In progress. 55 GMC 371 2 1/2 ton. Upcoming project. |
