03-11-2018, 11:45 PM | #1 |
I love factory bolts
I try to reuse them whenever I can. They have so much character. While I could easily find a functional replacement for the bolt below, it just wouldn't be the same.
03-12-2018, 02:31 AM | #2 |
Re: I love factory bolts
I prefer to do the same most of the time, have quite a few coffee cans full of OE bolts just waiting to be wire brushed when needed.
03-12-2018, 10:51 PM | #3 |
Carpe manana
I've replated essentially all the factory bolts on my current blazer build. I've been meaning to post a thread depicting the various makers marks used by GM. There are some very cool examples and all seem to have class above the lack luster plain new pieces.
Here are some pieces I got back today.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
03-12-2018, 11:07 PM | #4 |
Carpe manana
Here are two examples.
03-13-2018, 07:25 AM | #5 |
One of my favorite assembly line stories has to do with factory bolts:
On the squarebodies, the attachment of the front fender "nose bolts" to the rad support was especially tough, because it was blind and had awkward access. As a result we would cross thread the bolts often or (worse) break the weld nuts loose. Once you do that it can't be fixed on the moving repair line; it has to go into a stationary stall for repair. We discovered that there were two suppliers for a bolt that same size: One from Lang Fasteners and one from Ferndale Fasteners. The Langs would crossthread like crazy but the Ferndales wouldn't for some unknown reason, maybe because of the difference in coatings. The Langs (part number 3846202, btw!) were black phosphate but the Ferndales were silver cadmium. What we ended up doing was stealing a box of the silver bolts from Line 2 and run them all night with no issues, and then lock them up in our locker, set out a box of black bolts on the job and then go home. We did that for several years. First shift could never figure out why we didn't crossthread those bolts and why they had a mess on their hands every day. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-13-2018, 08:51 AM | #6 |
That story is rich! Cool to hear such stories.
I love my factory bolts, too, and save them like gems. I especially love the tapered tip you don't get with generic bolts. Really helps when bolted "aligned" parts. Helps guide them in. I just like them put together the same as factory since they did such a great job the first time around.
03-13-2018, 10:55 AM | #7 |
I replated a lot of my own little hardware for my truck restoration. I used the zing plating kit from Eastwood, and it worked pretty well!
If you have bolts you want to preserve I've cleaned them up on the wire wheel and then replated them, and it turns out pretty well, though it's time consuming!
03-13-2018, 02:22 PM | #8 |
At the body shop.
Pockets full from every pick n pull trip
" That didnt make it any newer " " Dont antique the equipment " |
03-13-2018, 05:50 PM | #9 |
I though a cross threaded bolt had like three times the holding power of a properly threaded bolt. Its like using thread locker with a lock washer topped off with a spot weld Why get rid of that?
03-13-2018, 05:59 PM | #10 |
Post Whore
In a previous life I spun wrenches on big bore CAT engines. Now I have a five gallon bucket of mostly 3/8" bolts from Caterpillar. Best darn bolts on the planet. But I'm all about reusing factory fasteners otherwise.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
03-13-2018, 06:27 PM | #11 | |
In either case someone buying a new truck deserves better than that (especially if they ever plan on taking that fender off). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 03-14-2018 at 07:11 AM. |
03-13-2018, 09:55 PM | #12 |
speaking of using oem bolts.... how do i clean my buckets full with my sand blasting cabinet?
1967custom |
03-13-2018, 10:00 PM | #13 |
Carpe manana
Mike try soaking some in Evaporust - you'll be surprised at how nice they'll turn out without having to replate.
03-19-2018, 12:46 AM | #14 |
That's what I do most of the time. They turn out great unless they are so rusted that I probably shouldn't use them.
