Help ac swap needs input
I installed a heat-ac unit from Limo between my front seats 72 c10 it has a block valve for refrigerant up front is r4 compressor with dryer and a dual switch pressure sensor for coolant my question is normally this system had two evaporaters up front and the rear im using do I need to make changes for not having front unit running? thought it might need sensor to shut off compressor if it becomes to cold
My Project Old Glory trike visit here http://www.facebook.com/home.php?#!/...48577705162172 |
Re: Help ac swap needs input
this mis the switch to regulate compressor
this is the unit with valve and air diverter
the compressor
I know the trinary opens the compressor circuit to prevent low or over pressure just not shure on other wireing needed to make this work !
Hard to tell exactly what you need. So this is basically like a rear air unit in a Tahoe/Suburban? It has no controls of it's own? Yes, you will need some way to control the system. A stock 67-72 system has a POA valve that regulates refrigerant flow and the compressor runs constantly. Later trucks have a cycling system with an accumulator and the compressor runs on demand. It sounds like you could use a cycling switch in the line between the evaporator and compressor, but I don't know exactly how the block valve works.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
Wow, Why?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
