Old 03-13-2018, 06:29 PM   #1
krue
Designated A-hole!
krue's Avatar
Wiring harness question
Noticing some issues with the harness on the 03 Savana 6.0l harness. I have an 01 Silverado 4.8l parts truck. Can I use that harness for my swap? Both are drive by cable. The truck was 4wd with the4l60e and the van is 2wd 4l80e.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 03-13-2018, 09:27 PM   #2
t300
Re: Wiring harness question
i used a 2001 silverado 4x4 4.8 harness on my 2002 6.0 lq4 motor. DBC and 4l60e. was my first LS rewire but went fine.
t300 is offline   Reply With Quote
Old 03-13-2018, 10:09 PM   #3
ls1nova71
ls1nova71's Avatar
They're basically the same harness, but vans use a different MAF, so you may need to change the plug. Also, you will need to re-pin the transmission connector to a 4l80e if that's what trans you're using, but it's pretty straight forward. http://lt1swap.com/4l60e_4l80e_harness.htm
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-13-2018, 10:27 PM   #4
krue
Designated A-hole!
krue's Avatar
I was planning on swapping the truck intake on the van, it's not as fugly. I assume that is doable.
www.daveramsey.com
Old 03-13-2018, 10:45 PM   #5
Dustytrix
Yes you can swap intakes,
Dustytrix is offline   Reply With Quote
Old 03-14-2018, 11:59 PM   #6
Flubyu
I’ve heard the van harness gives you more wire length...may help with pcm mounting.
'71 C-10 SWB Shop Truck
Currently 350/350, soon to be LS'd.
Flubyu is offline   Reply With Quote
Old 03-15-2018, 03:35 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The main "leg" of the van harness has a good deal of extra length (like 14-18" IIRC). My donor was from a truck, and I had my harness done on the van-donor style. Made moving ECM mounting locations easier imo.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-15-2018, 07:59 AM   #8
krue
Designated A-hole!
krue's Avatar
My van harness has sensor wires cut out, multiple butt splices crimped on, to include mystery wires added.
www.daveramsey.com
