03-14-2018, 10:56 PM | #1 |
hood adjustment on 55 2
Hi all what is the fix for hood that stays up in one corner when closed and have to push it down to close properly? Thanks Denis
03-15-2018, 08:39 AM | #2 |
Re: hood adjustment on 55 2
You need to place a shim under the upper hinge to cab bolts. This rotates the pivot point a bit to allow spring to work properly. Usually an 1/8" shim will do it.
Cheers, Jim |
03-15-2018, 10:09 PM | #3 |
ok thanks Jim will try that
03-15-2018, 10:51 PM | #4 |
You put a shim between the hinge and the hood at the front hinge bolt. OR you simply loosen the bolts on the hinge and push the hood open rotating the hinge back and tighten the bolts. You may then need to move the hood forward on the hinge.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
