03-16-2018, 11:47 AM | #1 |
Magnetic angle locator suggestions
I'm looking to buy a magnetic angle locator so I can set my rear axle pinion angle. I'm installing a rear Porterbuilt extreme setup. There seem to be so many angle locator brands out there with so many varying reviews on each. Anyone on here have a suggestion?
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24. /Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat / SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed |
03-16-2018, 01:19 PM | #2 |
Re: Magnetic angle locator suggestions
I have a Johnson brand but any of them should be fine. You can use your phone too.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
03-16-2018, 01:25 PM | #3 |
must have been reading my mind, thinking about this very thing.. gonna be welding mounts on my first axle mod very soon..
I'm all ears folks
I started out with nothing - and I still have most of it |
03-16-2018, 01:57 PM | #4 |
Hey! Did you sneak and take a pic of my rear axle and wheels? Looks just about how mine has for about the last 3 years. Just recently sent it out to be narrowed and rebuilt.
03-16-2018, 02:06 PM | #5 |
I've done many things over the years but I've never removed / installed a rear axle, much less one where I'm doing something such as installing a bagged parrallel 4-link (my PB stuff). So this will be a first for me. I'm mechnically inclined, know how to use the Internet, search this forum, and have Porterbuilt to call on so I "think" I will be fine ...
03-16-2018, 02:06 PM | #6 |
Thank you.
03-16-2018, 02:34 PM | #7 | |
those wheels are actually the 8 lug take-offs from my '65.. borrowed them from behind the garage to wheel that sucker around.. h e a v y! and 4:10 posi that rolls smooth and nothing butchered taking it to work this afternoon to pressure wash after shift tonight! you'll probably beat me to the actual task, I'm 3 years behind you and my schedule is probably slower than yours you lead, I'll follow.. good luck! thanks for the tip!
03-16-2018, 05:42 PM | #8 |
Post Whore
I have several of the digital magnetic angle finders...they're kinda noname brand but I've checked them against known angles and they are accurate......I got mine off ebay but lowes and hd have very similar ones
03-16-2018, 11:33 PM | #9 |
Do you have to calibrate them back to level every time? I was looking at these and it seems like you have to calibrate them.
03-16-2018, 11:35 PM | #10 |
Post Whore
the ones I have self calibrate when you turn them on....
03-16-2018, 11:36 PM | #11 | |
The Johnson 700 model says accuracy within +/- 0.30*. Much better. |
03-21-2018, 01:31 PM | #12 |
Thanks for the replies guys. I've been eyeballing a digital one I found on Home Depot's website. I've also been thinking about that Johnson 700. I'll probably go with the 700 from HD.
03-21-2018, 03:52 PM | #13 |
Post Whore
the ones I have are the same that baleigh indust sells....I got mine off ebay...
03-21-2018, 04:51 PM | #14 |
Nice. Thanks for that.
03-21-2018, 10:12 PM | #15 |
had this guy for years .
i love you can set zero on any surface then us that to find your current angle. so if the shop floor is NOT level you zero it on the floor and then go to town . saved me a lot over the years .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
03-21-2018, 10:14 PM | #16 |
also watch them old dana rears . they can be course spline axles in them . can be upgraded but cost as much or more than another whole newer axle .
i like dodge 94-up style fine spline and posi and abs tone ring for use with aftermarket speedo .
