Old 03-16-2018, 07:12 PM   #1
mwildman
Existing seat belt mounting 70 C10
I've searched the posts and vendor product data but don't have a clear answer.
Do 70 C10s have factory mounting holes in place to add 2 point seat-belts?
Is it as simple as ordering new/correct seat-belt model and bolting it in?
It's a stipulation of the seller that if/when she does sell me her truck, that I can't drive off until I have a seat belt installed.
It does have a cap in, for what assume is the 3-point mounting location, see image.
Is it safe to assume that the other mounting locations are in place?
Thanks for your time,
mwildman is offline   Reply With Quote
Old 03-16-2018, 07:20 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Existing seat belt mounting 70 C10
Yes, that plug is for the shoulder belt. Originals are very hard to find and expensive when you do....
Shoulder belts were an option and not many people opted for them. All trucks had lap belts. If you don't see the ones in that truck look under the seat. A lot of people just shoved them down through the crack between the cushion and back.
LockDoc
Leon
Old 03-17-2018, 12:13 AM   #3
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
Will be holes close to the gas tank mounting area and by the rear door jambs. It should be a 7/16"-20 thread welded in nut. Unless there has been some kind of floor repair and the holes filled.
http://67-72chevytrucks.com/vboard/a...1&d=1521259800
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
