Mounting cab before paint?
Should I install my rubber cab mounts or just set the cab and bed on the frame? My truck was blasted while off the frame. Thanks for any help.
Posted via Mobile Device |
Re: Mounting cab before paint?
Bump
Post Whore
![]() Join Date: Feb 2016
I'm not sure as to what you're asking. Do you want the bottom painted completely? If so then leave it off and lay it on its back so the painter can easily paint the bottom and firewall and likely some of the interior. But check with your painter to see what makes him happy.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: Feb 2009
At this point we're planning to spray the bottom, mount and paint. Just have to tape things off.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Stan 67 swb BLU MULE posted via flip-fone |
My truck was blasted top to bottom. I’m just asking should I install bushing now or wait till after the whole truck is painted underside included.
I would put the various bushings in. If any alignment or questions come up, it's sitting at the correct ride height. If you do any painting, you can clean the paint off the rubber parts, or if you're going to that much expense (painting top and bottom) and extra set of bushings is a negligible cost. Just my thoughts...
Post Whore
Are you planning on treating the insides of the voids under the floor? If so I would do that, then paint it off the frame, and then put it on the frame.
More than one way to do it, pros & cons to each. I suggest you mount the cab, doors, fenders, hood, cowl & grille so you can shim everything for proper fit BEFORE you paint it. Then you can blow it back apart to paint.
Or, you can paint the insides/undersides, assemble it, leave it together & spray the outside as one piece. Solid color I'd blow apart, metallic I'd spray with truck assembled. This is just me though, spray it how you feel comfortable. Side note: I enjoy cut & buff more when it's blown apart because it's easier to clean the compound out of the nooks & crannies. (if "enjoy" is the right word) |
#10 | |
Minty shop man. I would never leave except to get beer ![]()
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
