Active Member
![]() Join Date: Mar 2018
RPO code ??
I purchased a 72 Custom 10 deluxe a while back. I believe I'm the 4th owner. Somewhere along the line, the factory glove box door was swapped out with a chrome one. Thus eliminating the decal on the door listing the paint and options. Anyway to get this info using the VIN? Any help would be appreciated, thx.
Re: RPO code ??
Yer outta luck pal ....Unless built in Canada...
Stan 67 swb BLU MULE posted via flip-fone Last edited by harpo231; 03-18-2018 at 08:04 PM. |
All about them K’s
![]() Join Date: Jun 2014
Re: RPO code ??
You might be able to find a build sheet under the seat in the springs or stuffed around the gas tank somewhere. That’s about your only hope unless it was built in Canada as said above.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Active Member
Re: RPO code ??
Kind of had that feeling it was a lost cause. The gas tank was swapped out also from what I was told by the previous owner so that option is nill. I will check under the seats though. Thanks for the info, appreciate it.
![]() Join Date: Feb 2002
Re: RPO code ??
I found a fragmentary Build Sheet in the passenger door, when I was working on it. I put the jigsaw pieces in an envelope. Since lost it. Someone thought they were being 'helpful' by cleaning out my desk.
![]() Join Date: Oct 2009
Re: RPO code ??
I found TWO build sheets under my springs, one for my truck and one for the guy's truck that is still lookin for his build sheet! Probably before or after on the assembly line. Who knows.
