1967 c10 gauge cluster connector
Hey guys,
I have my 67 c10 and I'm trying to wire up my instrument panel and I believe the guy that had the truck before me cut the factory rectangle connector that goes to the back of the panel. I've called all around Houston and checked Craigslist for any junkers I could maybe go rob one from but have had no luck. Does any one have a place I can get one from. Thanks Last edited by LockDoc; 03-19-2018 at 11:03 AM. Reason: Can't post WTB |
Re: 1967 c10 gauge cluster connector
Deutsch Industries makes a good quality connector for that. DT-16 12 pin. Requires a bit to install but I hardwired my cluster using the DT-16 12 pin. Works great.
http://67-72chevytrucks.com/vboard/s...d.php?t=757997 |
Outback Truck Parts, Spring, TX.
They are closed on Mondays. |
You think they would have the factory plug? Or whole new wiring harness. I have never bought a wiring harness but I assume you have to splice your new harness to your old factory plug?
what gauges does your truck have?
Post picture. i may have the connector you need |
Outback Truck Parts has new and used parts. Call them and ask.
This is the only picture I could find until I get back home. That would be awesome if you had one.
Outback had one thanks fellas
