03-24-2018, 08:33 PM | #1 |
1971 GMC with manual 4 spd-what is the stock ratio???
So, i don't have any ratio listed on my glove box option sheet. What do the experts say was the std axle ratio for a truck that came with a 350 and a 4 spd manual. The 4 spd seems to have a very low granny gear in 1st....
Thanks for the future opinions. |
03-24-2018, 08:37 PM | #2 |
Re: 1971 GMC with manual 4 spd-what is the stock ratio???
Is the truck a half ton 3/4 ton or 1 ton? Also original motor and trans?
03-24-2018, 08:40 PM | #3 |
70+ ( Old Skool Club )
Here ya go.. I am assuming its a GMC 910 but I've added the GMC 920 specs as well.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
03-24-2018, 08:50 PM | #4 |
It is a 1/2 ton 1971 GMC. I was hoping for the 3.07!! I dont want to pull the cover off as it is very original and no leaks...
03-24-2018, 09:08 PM | #5 | |
Rear diffs are typically abused in the sense they get zero maintenance until they are broke or worn out.
03-25-2018, 03:47 AM | #6 |
Looking at the posted chart and if there is no optional ratio on the spid then you should have 3:07..
11-22-2018, 07:49 PM | #7 |
Second owner of a 71 GMC with 465 4 speed. SWB and it is a 3:07, now a 355 sbc still the 4 spd and 3:07
LILREDGMC |
