03-25-2018, 09:37 PM | #1 |
1971 4x4 Short Bed Fleet side Followed Me Home
Just brought it home yesterday. Don't know how original it is, no spid. Title, VIN plate, and frame stamp all match. It was born with 250ci IL 6, now has 327ci. Fender says Cheyenne, IDK? Has Tach, tilt steering, ralley wheels, 4 speed, front disc, front bumper guards, and usual rust. I'm super stoked.
We also Stopped by LMC's to get some accessories. My wife, one of my boys, and I were up until 1:00am and spent this morning changing master cylinder, rear wheel cylinders, and chasing down a clog in brake line to rear wheels (found it in separation block that attaches to rear axel and replaced). We also put on rear LED tail lights and cowl induction hood. Next we are going to replace the front bumper. Here are some Pictures. Following Me Home My Son's Hauler LMC for Cowl Hood, LED's, Shift Boots, Front Bumper Install Master Cylinder The Test Drive
1970 Jimmy 4x4 IL6 1971 Jimmy 4x4 350ci v8 1971 SWB 327ci v8 1972 Short Stepside 305ci v8 1972 Blazer 2WD CST LS9 350ci 4sp 1999 4 Door LB 1 Ton Old Body Style 5.7 v8 |
03-25-2018, 09:50 PM | #2 |
Re: 1971 4x4 Short Bed Fleet side Followed Me Home
SCORE! I like it, looks like a truck should
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
03-25-2018, 10:25 PM | #3 |
All about them K’s
I’m not seeing much of the “normal rust” in those pictures! Looks like a great score!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
08-04-2018, 08:50 PM | #4 |
Been working on my k10. Replaced Radiator, Radiator core support and support mounts, Passenger fender(used original), inner(chrome) and outer grille, battery Tray(stainless), valve covers, air breather, Wire gutters (core support and firewall gutters) heater box(used with new gaskets), heater core
Where it started 1. 2. 3. 4.
08-04-2018, 08:55 PM | #5 |
More.
6. 7. 8. 9. Before and after.
08-04-2018, 09:07 PM | #6 |
And more.
Engine before After Still need to clean up some wires.
08-05-2018, 10:44 AM | #7 |
Looking good so far brother. Nice score.
08-05-2018, 02:13 PM | #8 |
One of the First
Could be a Cheyenne, it has the rear cab light. Any welded up trim holes in the body panels? How about a headliner? If its a true 71cab, it will have a raised area where rear view mirror mounts to cab.
Looking good though!
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
08-06-2018, 07:38 PM | #9 |
Moderator
Safety suggestion...
Swap out that plastic bodied fuel filter for a metal cased one... Plastic over time will crack due to under hood heat... Nice truck! |
08-06-2018, 09:02 PM | #10 |
08-06-2018, 09:16 PM | #11 |
Thanks for the advise. It did help me solve a rusty tank problem though. After I completed the first phase of the fixer up brakes and all. I took it to the carwash and almost didn't make it. So I replaced the cheapest first. Fuel filter with clear plastic. It clogged up really quickly with rust that I could see through the clear filter. So out with the tank, tank to a local tank wash, back in which lead me to carb bowl full of rust. So now that all is running good, and clean. I think a metal filter is tomorrow's project
