Old 03-28-2018, 08:14 PM   #1
Casey66
Help identify disk/drum master cylinder
I've been re-plumbing the brakes on my '66 shortbed step and am now needing to replace the master cylinder, it's been leaking. Problem is, one of the POs upgraded to a dual master cylinder/brake booster setup and I don't know what it's off of. I'm running disks in the front and drums in the back. The only thing I can read on it are a tag saying "0094" and another saying, i think, "223223LA" or "2232231A". Several searched turn up nothing for any of that.
If anyone can id the brake booster also, that'd be helpful too.
Any help is appreciated.
1966 Chevy c10 SWB Stepside, SB 350.
Casey66 is offline   Reply With Quote
Old 03-28-2018, 10:11 PM   #2
350TacoZilla
Re: Help identify disk/drum master cylinder
at a glance it looks mid 70's-80 C/K10
350TacoZilla is offline   Reply With Quote
Old 03-28-2018, 11:54 PM   #3
Captainfab
60-66 Nut
The booster is a '73-'80 and the master is likely as well.
Old 03-29-2018, 11:35 AM   #4
Casey66
Thanks ya'll.
OK, so if I got a replacement from that year range, with the same bore size, it should work? Something like this: https://shop.advanceautoparts.com/p/...aster+cylinder ?
Old 03-29-2018, 12:47 PM   #5
350TacoZilla
Should be the same, I kept thinking the 73&74 trucks used a different one than 75-80 but I might be wrong. I would measure your current one to make sure you get the same one as I believe there is 2 different sizes (but again I'm going off memory here).
Old 03-30-2018, 11:09 AM   #6
Casey66
Got a replacement for a '77, in the link above, and it bolted right up. Thanks all.
brake booster, brakes, disks/drums, master clinder
