Old 04-02-2018, 11:57 PM   #1
WOLFMANmike
WOLFMANmike's Avatar
removal process of inner fender well
hey guys so i have a question on the 65 c10 can i remove the inner fenderwell without having to take off the entire outer fender ? and if so would you maybe explain the process for me ? thanks guys
WOLFMANmike is offline   Reply With Quote
Old 04-03-2018, 12:47 AM   #2
UKNOWME
UKNOWME's Avatar
Re: removal process of inner fender well
Interested as well.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 04-03-2018, 08:01 AM   #3
PGSigns
PGSigns's Avatar
Nope the fenders have to come off. Here is how I get them out. You will have wiring to remove.
1 Pull the hood then the fenders
2 Pull the radiator and the battery tray
3 Pull the grill
4 Remove the bolts holding the core support to the frame and I will pull the bumper most the time since I like to clean and paint while I have stiff apart and it does make it easier to move the core support forward.
5 Remove the 2 bolts coming from the front that are behind the grill and the three from under the inner fender that go into the core support that hold the inner fender.
6 Remove the core support. It needs to come forward about 2 inches.
7 Remove the cover plate on the drivers side where the steering shaft goes through.
8 Remove the bolts at the fire wall and the inners will be free.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-03-2018, 09:45 AM   #4
WOLFMANmike
3 Pull the grill
Jimmy
Ok thank you very much PGsigns
Old 04-04-2018, 11:57 PM   #5
rvrfoot
rvrfoot is offline   Reply With Quote
Old 04-05-2018, 08:27 AM   #6
UKNOWME
UKNOWME's Avatar
So you have to disassemble to whole front clip? Wow that’s crazy
1964 Chevy c10
Old 04-05-2018, 07:38 PM   #7
Vincenthdfan
That's how I did mine...just pulled the whole front clip intact.
Vincenthdfan is offline   Reply With Quote
