Old 04-04-2018, 01:58 PM   #1
D13
D13's Avatar
Seat belts - bucket vs bench
Looking at having to replace my seat belts on my bench seat 83 C10. My inner belts are fine, the main belt (that goes to the retractor) is toast. Found a set that look good but they are in a bucket seat 'burb. Are the main belts the same or at least as long? It looks like the retractor is a bolt in, and again my inners and centers are fine.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 05-15-2018, 06:22 AM   #2
D13
D13's Avatar
Re: Seat belts - bucket vs bench
Someone knows this...
Think of it the other way - who has done a bucket seat swap into their truck? And did you reuse the bench belts with no porblem?
1987 2 ton
Old 05-20-2018, 01:47 PM   #3
Pontiac1976
Pontiac1976's Avatar
The (retractor) for 77-87 beanch seat do not hold up the the seat up, mount on the uper out side of the beanch in the 77-87 cab. So if the bucket seat belt (retractor) Does not mount under the corner on the seat it should work. But year style maybe different fastner male to female ( buckles ends) to fit in to each other.
Does this help you?
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 05-21-2018, 06:36 PM   #4
USSkoval
Burb seatbelts are different than regular cab pickup seatbelts. But as far as regular cab pickups go, the outer (3point) belts are the same between bench and bucket seats.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 05-22-2018, 06:46 AM   #5
D13
D13's Avatar
Thanks guys. Looks like I need a drivers side maroon belt out of a pickup, bench or bucket. Darn it, the ones I found were out of a burb.
Sigh.
1987 2 ton
