04-06-2018, 08:54 AM | #1 |
66 carb id and question
66 long bed c10. In-line 6, assuming original. Truck runs good but after sitting all winter, I had to put a little fuel down carb to get her to fire. When I did this, I noticed a little seepage from shaft pivot(?). I would assume that means theres air leaking as well? Also would like to do clean up and rebuild on carb. What carb should be on there? I have no reason to believe its not original equipment.
Thanks, John. |
04-06-2018, 08:26 PM | #2 |
Re: 66 carb id and question
Fuel will run out the shaft when you dump fuel down it. Does not mean there is a problem.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
04-06-2018, 11:21 PM | #3 |
Thank you for the reply. Appreciate it.
04-07-2018, 01:28 PM | #4 |
Throttle shafts will leak a little bit, that's normal. If you can wiggle the thing back and forth and actually see that the shaft moves laterally, that's a vacuum leak which may cause some funky idle issues.
They can be repaired but it takes special tools.
Everybody has to believe in something. I believe I'll have another beer. |
