Old 04-06-2018, 06:31 PM   #1
miller6t9
miller6t9's Avatar
updated OEM replacement brake rotors
can anyone point me in the direction of a set of front rotors for a '72 for use with Wilwood d52 calipers.....and something that will still fit behind a 15 inch wheel?
miller6t9 is offline   Reply With Quote
Old 04-06-2018, 08:16 PM   #2
Rich69shortfleet
Re: updated OEM replacement brake rotors
Maybe ask Wilwood? The guys on their tech line are pretty good.
Rich69shortfleet is offline   Reply With Quote
Old 04-06-2018, 10:24 PM   #3
Pro299
Junior Member
Any stock or upgrade replacement type rotor will work. I have the Willwoods with Stop Tech rotors and AR 15X8 wheels. Fits fine. Any 15 inch wheel that works with the stock rotor and caliper should work with the Willwood D52s.
Pro299 is offline   Reply With Quote
Old 04-07-2018, 06:50 AM   #4
miller6t9
miller6t9's Avatar
Do you have any idea what the part number is for the stoptech rotors? I see there are several just from a Google search and the stoptech website apparently doesn't give out that info.
Old 04-07-2018, 10:40 PM   #5
Pro299
Junior Member
I think I got mine off Amazon using their search by vehicle. They were 126.66000SL and SR. These were the slotted. They also were available plain, drilled, or drilled/slotted.
