Fitment
After doing some research on this site I think I have my answer but wanted to verify from all of those who are wiser in the c10 force than I. Would a 1976 c10 12 bolt Posi rear end with 4.10's be a direct bolt up replacement to my 1965 C10 12 bolt rear end?
Pat |
Re: Fitment
No!
Re: Fitment
I think the 76 is wider.
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Fitment
76 will be 1.5” wider, .75 each side. Also if you have could springs, you will need to remove the leaf mounts and add trailing arm mounts, Captn Fab makes them and sells here on the forum. I don’t know if I would go with 4.10:1 rear, might make hwy driving noisy and harsh.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Re: Fitment
Ok thanks. I will stick with what I have. Thanks for all of your comments and help.
Pat |
