04-09-2018, 03:41 PM | #1 |
Rims
What year trucks have the same bolt pattern on the rims as ours? Need to find one for a spare.
Never drive faster than your Guardian Angel can fly Larry |
04-09-2018, 04:24 PM | #2 |
Re: Rims
Well is your truck the 1/2ton 6 lug or 3/4-1ton 8 lug? The 6lug pattern is 6x5.5 the same as basically 67-current chevy 4x4 1/2tons and also same as most toyota,nissan, some isuzu's lol The only thing to watch for is 88+ chevy trucks usually have a smaller hub diameter in middle unless they are aftermarket wheels. Tire size is important too so try to get the closest size to what is on your truck already especially if your truck has any type of locker or limited slip you can ruin locker/limit slip by running 2 different size tires on those.
If your truck is 8 lug it is 8x6.5 and pretty much the common 8 lug bolt pattern for 3/4-1ton trucks and vans from 60's-2000's only one's to really watch for is starting in 99 ford super duty trucks use 8x170mm bolt pattern and in 2011 chevy/gmc trucks switch to 8x180mm. I actually had a 2003 ram wheel on my 1963 GMC for a spare that fit just fine to load it on trailer and have 01 tundra wheels on my sierra parts truck to move it around. |
04-09-2018, 05:37 PM | #3 |
Re: Rims
Thanks tacozilla
