Old 04-10-2018, 12:29 PM   #1
slowcpe
slowcpe's Avatar
18" Wheels: Tire sizes
I've had a set of 18x8/9.5 Ridlers for a few years with 235/55-18 on the front and 255/55-18s on the rear. The fronts at about shot and I've currently got them on my '72 driver. I'm planning on putting a set of 20s on it later this year and the 18s back on my '67 project to roll around the garage in.
I'm finding there is not a whole lot of 18" tires in the 27-29" tall range which I'd like to have since I have a 4.11 rear end. The 255/55s are about 29" tall. A guy at one of the local tire shops has a set of Michelins in 235/60 and 265/60 I can get real reasonable that could get me by until the budget allows for new tires/wheel. The fronts would be about 29.5" tall and rears 30.5" tall.
Anybody running either one of these tires? I'm curious if they would be too tall and look kind of goofy. Truck is getting lower about 4" in the front and 5" in the rear here real soon.
Current setup:
Anybody want to post up pics of your 18s and tire sizes?
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 04-10-2018, 12:49 PM   #2
bigmac73
bigmac73's Avatar
Re: 18" Wheels: Tire sizes
this does not make since to me , you are going to run a 60 series tire all the way around and that means that the sidewall height should be same , just a wider tire in the back
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 04-10-2018, 12:53 PM   #3
beaterku
beaterku's Avatar
I am running 265/50/18 all around on 18x9's. You are right that there are not a lot of tires in this range. I am possible thinking of going to a slightly shorter tire in the future. Maybe a 45 series tire.
beaterku is offline   Reply With Quote
Old 04-10-2018, 01:06 PM   #4
slowcpe
slowcpe's Avatar
The 60 is 60% percent of the width of the tire so a 265/60 would be taller than a 245/60.
Ryan
Old 04-10-2018, 02:07 PM   #5
slowcpe
slowcpe's Avatar
Truck looks good. If I go shorter I probably need to change the rear gear.
Ryan
Old 04-10-2018, 02:52 PM   #6
RustyBucket
RustyBucket's Avatar
I bought a set of off brand (CHEAP) 255/55r/18's for the Blazer. 18"x 9" Torque Thrust all the way around. It sits almost level and they fill up the openings pretty well. No rub. So far I'm pleased with them. They're "V" rated and seem to be pretty sticky... wrung my driveshaft off first time I dumped the clutch.
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 04-10-2018, 05:20 PM   #7
68Stepbed
68Stepbed's Avatar
255/45/18 front and 295/45/18 in rear is a good combo.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 04-10-2018, 05:39 PM   #8
Kennuck
Kennuck's Avatar
255/55/18 front 275/60/18 rear Ridler 18X8 front 18x9.5 rear 2.5/4 drop
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 04-10-2018, 06:28 PM   #9
RodnRudy
RodnRudy's Avatar
Here's a link to a tire size site. Lots of good info here
https://tiresize.com/calculator/
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 04-10-2018, 06:51 PM   #10
slowcpe
slowcpe's Avatar
I agree but those rear tires are too expensive to put on a cheap set of Ridlers
Ryan
Old 04-10-2018, 06:53 PM   #11
slowcpe
slowcpe's Avatar
Hmm. That looks good.
Oh I’ve spent some time there. Lol. Good site.
Ryan
Old 04-12-2018, 12:01 PM   #12
bigmac73
bigmac73's Avatar
There you go reminded something new everyday, i had forgotten that
Mike
Old 04-12-2018, 03:17 PM   #13
Custom 68
Custom 68's Avatar
Here is mine
Fronts are 255/55-18
Rears are 285/50-18
9.5 inch wheels
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 04-12-2018, 03:19 PM   #14
Custom 68
Custom 68's Avatar
I bought these a few years back and had a real hard time finding sizes I liked. These are Toyo Proxy ST2 if I remember correct.
Dave
Old 04-13-2018, 07:12 AM   #15
SIXTY9
I bought Master Craft tires, 285-60R-18 for the rear and 265-60R-18 for the front. I only lowered the rear 2" and the front 2 1/2 in the front. This picture is after I removed engine and transmission for paint and rebuild. I did not see any rubbing issues with the front or rear. The wheels are Ridler 18X8 front and rear.Name:  IMG_0592.jpg
SIXTY9 is offline   Reply With Quote
