Old 11-10-2003, 04:45 PM   #1
Mark540
WTB - Disk brake assembly, 6-lug ralleys
Looking for disk brakes from the knuckle out on a Dana 44 front(trying to save shipping costs). Also could use some 6 lug ralleys any shape except bent. Looking for brake assemblies in the $40 or less range otherwise it would probably be better to source locally because of shipping costs.
Thanks,
Mark
1970 GMC Burb 4x4 - 68 Chevy Front, FI LT1, 4L60E
1970 Chevy Impala 47,000 miles
2001 BMW 540i 6-speed
2002 Dodge Ram 1500 4x4 w/20's
Mark540 is offline   Reply With Quote
Old 11-10-2003, 05:26 PM   #2
Burnsman
Chevy Freak
Burnsman's Avatar
dana 44 ft discs
I may have some 6 lugs coming in. I have 3/4 ton complete front axles now. I'm not sure how far fairborn is. I live about 45 minutes from youngstown. Let me know. Thanks.
69 GMC SWB, 350
70 Chevy LWB, 350
55 chevy gasser, 461
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
Burnsman is offline   Reply With Quote
Old 11-10-2003, 06:01 PM   #3
Mark540
Burnsman,
What ratio is in the 3/4 ton? Disks I assume? Do you have a 3/4 ton rear to match? If so how much? 4 hours from you roughy not too bad.
Mark
Old 11-10-2003, 06:04 PM   #4
REDWHITE402
Guest
Posts: n/a
I have a set with caps and rings$200 plus shipping
Old 11-10-2003, 06:14 PM   #5
Mark540
Thanks, Redwhite402, I was looking to spend a little less, I was trying to find some inexpensive ones before I opt for some eagle alloys instead.
Old 11-10-2003, 06:28 PM   #6
Burnsman
Chevy Freak
Burnsman's Avatar
3/4 ton axles
I have a set of axles (dana 44 ft/dana 60 rear) that came out of a 71 gmc 3/4 ton. The front has discs. $200 for the pair. The gears are 4.10 I think. The rear is an open rear. Let me know. Thanks. Or you can call me at 814-333-2704 if interested. Brian
69 GMC SWB, 350
70 Chevy LWB, 350
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
Old 11-10-2003, 06:32 PM   #7
Mark540
Brian, could you verify the ratio and I will do some checking on wheels to fit? I will research tonight, I am definately interested. Thanks, Mark
Old 11-11-2003, 09:45 AM   #8
Burnsman
Chevy Freak
Burnsman's Avatar
axles
I will try to verify tonight.
69 GMC SWB, 350
70 Chevy LWB, 350
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
Old 11-11-2003, 10:03 AM   #9
Mark540
Brian, do you happen to know what is involved with going from a 1/2 ton axle to a 3/4 ton axle? Just don't want to get over my head here. If it is to involved I can wait for the 1/2 ton fronts you will be getting.
Old 11-11-2003, 10:18 AM   #10
Burnsman
Chevy Freak
Burnsman's Avatar
differences
Mark, I'm not real sure. I think it is physically a bolt in. The only real difference being the 8-bolt lug pattern vs the 6. But maybe someone on the board will know. There are some pretty smart people on here.
69 GMC SWB, 350
70 Chevy LWB, 350
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
Old 11-11-2003, 10:40 AM   #11
Mark540
Thanks, I will pose the question on the message forum.
Old 11-11-2003, 10:54 AM   #12
Burnsman
Chevy Freak
Burnsman's Avatar
Mark, I have a set of 1/2 tons that I was going to sell to a local, but he backed out of the deal. Front is dana 44 w/ discs, rear is 12 bolt posi. Gear ratio is 3.08. Front axle is missing lockout hubs (I think they are about $100/pr new). $200/pr. I also have a complete 72 1/2 4x4 truck. You could have the whole truck for $500. It's minus motor and bed. TH350 is a year old and it has the NP205 transfer case. The front has discs. The rear is the open style. Gear ratio is also 3.08.
69 GMC SWB, 350
70 Chevy LWB, 350
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
Old 11-11-2003, 12:27 PM   #13
Mark540
Brian, OK now you have me interested, problem is room. I could use the trans/transfer combo, column, pedals, brake booster/propotioning valve(disk), front drive shaft, and front axle. I don't have room for a whole truck, and I live in an alotment where restrictions won't let it outside. Would you concider parting the truck using the axles you have unattached and keep the truck rolling if you have the ability to get rid of it?
Old 11-11-2003, 12:45 PM   #14
Burnsman
Chevy Freak
Burnsman's Avatar
truck/axles
Mark, It's alot more work for me, so it would need to be worth my while. I do have a way to get rid of it. Just to be sure, here is what you want: the 71 axle set (w/posi), the following parts off of the 72 (xfer case/trans, pedals, booster/prop valve, column, ft driveshaft). You may want the ft axle off of the 72, as it still has the hubs and has the same ratio. What were you thinking price-wise? I'd need some form of a deposit (like $100) in a money order. I could have it all rippedoff and ready to go and you would just need to come and get it all. Let me know. Thanks.
69 GMC SWB, 350
70 Chevy LWB, 350
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
Old 11-11-2003, 01:05 PM   #15
Mark540
Brian, yeah the more i think of it is alot of work I don't want to put you through. Does the truck have a title?, longbed? Might be able to get it in the garage and rent a car trailer. Maybe I could get the front axle as well(with no hubs) to keep the truck a roller.
Old 11-11-2003, 01:24 PM   #16
Burnsman
Chevy Freak
Burnsman's Avatar
truck/axles
Mark, here is a couple of pics of the truck. I am at bottom dollar on both items. $200 for the pair of axles and $500 for the truck. The truck has a good title. Just let me know what you want to do. Thanks.
69 GMC SWB, 350
70 Chevy LWB, 350
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
Old 11-11-2003, 01:28 PM   #17
Burnsman
Chevy Freak
Burnsman's Avatar
#2
#2
69 GMC SWB, 350
70 Chevy LWB, 350
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
Old 11-11-2003, 01:29 PM   #18
Burnsman
Chevy Freak
Burnsman's Avatar
#2 again
whoops
69 GMC SWB, 350
70 Chevy LWB, 350
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
Old 11-11-2003, 03:14 PM   #19
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
Thats the nicest 500$ truck i have seen in quite a while.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 11-11-2003, 04:02 PM   #20
Mark540
Well talked to the wife and thought about things over lunch. I really would like the truck but I just don't have room it, so lets get a price on some items and I will send a certified check and pick them up in a couple of weeks(if that will work for you). I want to keep this rolling so you can sell what is left(frame and title have to be worth some pennies). Things I would want: Front driveshaft, front axle-no hubs(71), 350 and TC, brake master cyl and proportioning valve, and possibly the column and pedal assembly. I can help with the removal if need be, what would you want for these things?
Old 11-11-2003, 04:55 PM   #21
Burnsman
Chevy Freak
Burnsman's Avatar
truck/axles
Mark, I really hate to piece-meal this truck out. I just don't want to get stuck with something I can't sell. If you want, I'd sell you the truck for $500 and I'll strip the transfer case/trans/front axle w/hubs/ft driveshaft, booster/mc/prop valve/column and pedals. I can get rid of the rest. Let me know. If you want the other front axle w/o the hubs, I'd sell it seperately for $60. Let me know. Thanks.
69 GMC SWB, 350
70 Chevy LWB, 350
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
Old 11-11-2003, 06:56 PM   #22
Mark540
Brian,
I will talk to the wife again tonight and may just get the whole truck, I will let you know tomorrow. Do you think it can be towed with a tow bar 250 miles or so?
Thanks,
mark
Old 11-11-2003, 10:26 PM   #23
Mark540
Brian, talked to the wife, I will take the truck complete. Let me know where to send the deposit. I believe I can make it up next weekend to get it.
Thanks Mark
Old 11-12-2003, 09:57 AM   #24
Burnsman
Chevy Freak
Burnsman's Avatar
Truck
Mark, the truck should be able to be towed with a tow bar. It rolls freely, nothing is loose. It does have alot of good parts on it. It's got power steering box, sliding rear window, etc. I'll get the title dug out. Send the deposit to Brian Burns, 15827 Bailey Rd, Meadville, Pa. 16335. Thanks. Just let me know when you are coming to get it. You can call me at work til 5 (814)382-8691 x305 or at home 814-333-2704.
69 GMC SWB, 350
70 Chevy LWB, 350
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
Old 11-12-2003, 04:57 PM   #25
Mark540
Brian, my wife got a certiied check for a $100 deposit and will mail it today. I am shooting for next Sat morning(22nd) to be up there. Let me know if that will fit you schedule.
Thanks,
Mark
