04-21-2018, 09:34 PM | #1 |
77 k20 carrier bearing mounting ???
Hello
I'm building a 77 K20 frame up so I can swap my body over this summer. Today I picked up the trans (sm465), transfer case (np205), and driveshafts from a 79. The rear is a 2 piece shaft but I don't see a place to mount the carrier bearing on the frame. Does anyone have a picture of where it goes, Please.
87 V20, Vortec 350, Sm465, Np205, Dana 44, 14bff 4.10's |
04-22-2018, 07:19 AM | #2 |
Re: 77 k20 carrier bearing mounting ???
Hmmm, my 76 has a one piece drive shaft and that's all I usually see on square body 4x4's. I guess I must not have spent much time under 79 and newer 4x4's.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
04-22-2018, 07:45 AM | #3 |
i had one with a 2 piece shaft . you get another whole cross-member and bracket for it .
ditch the 2 piece shaft and just go 1 shaft .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
04-22-2018, 08:02 AM | #4 |
To use the 2 piece drive line you will need to remove the rear cab brackets and replace them with a crossmember that holds the rear cab and has the plate for the carrier bearing.
