Old 04-30-2018, 12:58 PM   #1
The Rocknrod
Moderator
The Rocknrod's Avatar
Hood Park Lamp
On a 64 Chevy - On the hood park lamp housing, Anyone know what size screws hold those to the hood? Just 2 screws each?
And what size is the hole for the bulb/socket assembly to fit into?
Thank you for the info.
My 'truck in a box' didn't come with them. Thank you.
Old 05-01-2018, 05:11 AM   #2
The Rocknrod
Moderator
Re: Hood Park Lamp
The only reason I ask is so I can order a plug for each side and the housings and maybe buy the correct screws locally to save a week here then a week there...
Old 05-01-2018, 06:33 AM   #3
PGSigns
PGSigns's Avatar
Re: Hood Park Lamp
I think the screws are 8-32 by about an inch long. I have some housings at home I can measure tonight, and they are about 1 1/8" with a tang slot in the front. You may want to order the harness so you get the plug for the fire wall end.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-01-2018, 09:35 AM   #4
The Rocknrod
Moderator
Re: Hood Park Lamp
Jimmy
Thanks Jimmy, I already have firewall plugs and connectors two sets of everything from different kits.
I want to make one piece of wire from the bulb contacts back to the firewall is all. I have leftover bulb contacts and was going to buy a new plug and make the ends there. Want to buy it from the Repair Connector Store.
