04-30-2018, 11:09 PM | #1 |
window glass
Can anyone help me. This will be my first time installing any kind of window parts on a door. however I am going to try and install all new window parts in my new doors on my 69 step side. It appears that the window sash channel is what helps holes the window regular in place do the window sash and the glass setting rubber get glued to the bottom of the window? if so what kind of glue should I use on it? any help would be great it is very expensive to have a body shop install these window parts so I have to at lease try and install it for myself to save money to complete my build.
05-01-2018, 12:29 AM | #2 |
Post Whore
Re: window glass
There are a bunch of threads on this subject. Here are a few. Do a search for more if these don't answer your questions.
Good luck! http://67-72chevytrucks.com/vboard/s...d.php?t=157539 http://67-72chevytrucks.com/vboard/s...d.php?t=732400
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-01-2018, 09:29 AM | #3 |
Re: window glass
thank you for the support I will check them out
08-07-2018, 07:35 PM | #4 |
Re: window glass
Did you ever get your question answered? Neither one of those links explained how the sash is connected to the glass. I have the same question and have not found a definitive answer.
08-07-2018, 07:39 PM | #5 |
Re: window glass
There are basically two methods. The old fashioned way is to use glass setting tape. Glass setting tape is a cloth tape that's infused with butyl rubber, and it forms a compression fit as the channel is installed on the glass.
The second method, used in more modern manufacturing, is to glue the channel to the glass. There are special epoxies made for this purpose, but windshield urethane works well also.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
08-07-2018, 08:06 PM | #6 |
Re: window glass
I used silicone. Has worked great for me.
08-07-2018, 09:25 PM | #7 |
Re: window glass
You can use silicone, but there's a reason it's not used for auto glass. It doesn't hold up well over time in that application. You can buy automotive urethane at most parts stores. You could use something like JB KwikWeld. It's a little less flexible than actual channel adhesive, but it should work. You don't need to fill the entire channel; just a couple of inches at each end will hold the glass securely.
