Old 05-02-2018, 12:42 PM   #1
curvedglass
curvedglass's Avatar
Weird Wipers
About two weeks ago I took out a deer with my daily 63. Poor SOB didn't have a chance. That 55 year old steel knocked his **** right onto my headlight bucket! Few wrinkles and misaligned panels but for the most part if you do not know what you are looking at the truck looks ok.
Here is the biggest issue however - my wipers came on at impact and I can't shut them off without pulling the fuse. Anyone have an idea what may have happened?
I do not use it much in the rain but if I am out and about it sux. RainX is useless on knee knockers. About as much aerodynamics as a brick.
As always any info is greatly appreciated.
--Life looks better through a curved windshield--
curvedglass is offline   Reply With Quote
Old 05-02-2018, 05:34 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Weird Wipers
Check the wiper switch first to see if disconnecting some of the ground leads turns off the wiper when the ignition is on. If not, the wiper motor is probably grounding near the mount at the firewall since there is constant power to the wiper motor.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
